1 should I replace this clutch friction plate? Sat Jun 20, 2009 4:37 pm
roys
hi,
I have had serious oil leak and the suspect is seal between eng and clutch.
As this is a good opportunity to replace clutch friction plate I got one from motobins (as well as seals).
Today I removed clutch and found out that entire assembly is fouled with eng oil - I am surprised I felt no more than a slight hesitation when accelerating.
"anyways" after cleaning existing friction plate with petrol (it now feels very dry to touch) I measured and it is exactly 5mm (practically new) whereby as per Haynes standard width is 5.05-5.55mm and allowed min is 4.50mm.
So my question is should I keep the original friction plate in bike?
This can be broken down to more exact questions:
1) Can friction plate be “trusted” after being fouled with oil and cleaned? I remember somewhere a saying that it cannot but wonder what joined wisdom of group says?
2) How many Km are left in my original clutch assuming I am a pretty reasonable driver? I do no more than 6000KM a year on bike.
Thank you,
Roy
Thank you,
Roy
