1Back to top Go down   visor mechanism Empty visor mechanism Mon Jul 28, 2014 1:25 am
michaellaw
michaellaw
What have i got my self into these things are gold 350 out of melbourne
2Back to top Go down   visor mechanism Empty Re: visor mechanism Mon Jul 28, 2014 1:31 am
Is it the electric screen you refer to Mick
3Back to top Go down   visor mechanism Empty Re: visor mechanism Mon Jul 28, 2014 2:08 am
michaellaw
michaellaw
Yes one of the arms are broken which has caused the motor to burn out it hasn't been serviced for years it's had it basically
4Back to top Go down   visor mechanism Empty Re: visor mechanism Mon Jul 28, 2014 3:10 am
The arms are available from Motobins ($32 I think it was) and the sunroof motors from the BMW cars are the same.
I think its all the cars but I know that my 320i is the same and Inge had a 5 series and said it was the same.  I have seen them on ebay for around $70.
If you do fix it use the dry silicone spray to lube it as it doesn't attract any dust.
5Back to top Go down   visor mechanism Empty Re: visor mechanism Mon Jul 28, 2014 5:02 am
michaellaw
michaellaw
Ok I'll give it a go I can get one out of Germany for about 250 but I recon I'll have a go at fixing this one if I can buy the arm
6Back to top Go down   visor mechanism Empty Re: visor mechanism Tue Jul 29, 2014 11:21 am
k75RT Keith
k75RT Keith
go to realoem.com and Put the motor p/n in That should give you a cross refernce for other modles using the motor.
7Back to top Go down   visor mechanism Empty Re: visor mechanism Tue Jul 29, 2014 10:53 pm
Dale S
Dale S
I managed to find the whole retractor/motor mechanism on e-Bay for
150 US$.  It cleaned up very nicely and operates flawlessly.
1990 BMW K100LT
 2003 BMW 540i
 1998 Ford f-150
8Back to top Go down   visor mechanism Empty visor mechanism Sat Aug 16, 2014 9:05 pm
michaellaw
michaellaw
missed out on one from the states for $107.00 au with a pooftenth of a second to go some goose came in with an extra bid his internet must be faster than mine or im just slow  🇳🇴
9Back to top Go down   visor mechanism Empty Re: visor mechanism Sat Aug 16, 2014 9:34 pm
I have found that to snipe on an ebay item in USA you need about 7 seconds to spare or you can just miss it but in Oz 4 seconds will do the job.
