MikeisonTV wrote: Update...well if anyone has a badge of douchetardery I need to borrow it so I can wear it. I removed the gas cap and shazam...the neg line on the fuel pump was loose. No more sputter...now back to this cutoff issue. I have developed a massaging of the clutch technique that prevents cutoff, but makes her high maintanence to ride...
Glad you were able to sort that out Mike but seriously, don't be so hard on yourself. Sounded def like a fuel supply problem.... but back to the clutch/throttle>>engine dies problem.
Been away for a week and as I read those few posts just now I thought there was a solution coming... alas.
Rabidchiwawa007
Thanks for the input mate but much of that has already been suggested. I've spent hours going over my ol' girl cleaning connections, rerouting cables testing sensors and relays etc. Haven't looked at hall effect sensors, coils etc because...
1. the bike performs like clockwork in all other respects... everything works!
2. the symptoms are very specific. There are no ifs buts or maybe's. When you throttle off and disengage the clutch the engine dies instantly but can then be immediately restarted.
Really... we know its the gotta be the ECU, I've tried everything else. Just gotta get around to doing a swap to confirm this. Finding the time to take up those kind offers above to do that has been a problem for me recently. Will be heading down to Newcastle for a week and then to Sydney for a weekend in second half of Sept. There could be an opportunity there if there are any kind bricksters in Newcastle.
I've had a bit of a look around and there doesn't seem to be too many ECUs on the market. Found one on ebay but it was over $400. Anyone got any suggestions as to what my options are with replacing the ECU? I read somewhere that there is a substitution option but I now can't find the article/post.
I did ask previously, but can anyone point me towards a schematic of the ECU ??
Just a thought, but apart from MikeisonTV has anyone else tried to replicate this problem. It's not something you would come across under normal operating conditions so might go un-noticed in most cases. Simple to try...
1. At 4-5,000rpm roll throttle right off.
2. Pull clutch lever in.
3. Engine should cruise back down to idle
OR battery and oil lights come on and engine stops.
