51 Re: sprag sprague clutch easy fix diy Fri Apr 29, 2016 12:41 pm
NOT Diesel fuel but lubricating oil designed for use in diesel engines.Danish biker wrote:Dai wrote:Quite some while ago, after dumping diesel dinosaur pee in LFB (because that was all that was available at the time and I needed oil desperately), I asked an army-trained vehicle mechanic (who is also a biker/triker) if it would do any damage. His response - which bears out everything said above - was 'No. Diesel engine oil is designed for tougher environments than petrol engine oil and, if anything, will clean the sh!t out of your engine'.
Pushing 33 years as a infantry officer I can only say you are right. I got the same advice from some of all the army mechanics I've served with both in land and in missions throughout the world. How ever I'll try the cleaning liquid for 30 minutes, in a hot engine first. And then the Castrol I bought. If it doesn't help I'll probably use diesel fuel
Any last remarks before I try the trick tomorrow?
