1Back to top Go down   Clutch disengage Empty Clutch disengage Sat Jun 14, 2014 11:27 am
jlmk100
jlmk100
Managed to get the bike to crank over ok via slave battery .
The clutch wont disengage although the arm moves when you use the lever .
Thoughts on sorting this ? I do plan on taking the engine out when I start properly so if nec will separate if nec was going to leave connected if all ok.
2Back to top Go down   Clutch disengage Empty Re: Clutch disengage Sat Jun 14, 2014 2:08 pm
k-rider
k-rider
How far can you pull the lever before you fell any resistance?
K-rider
3Back to top Go down   Clutch disengage Empty Re: Clutch disengage Sat Jun 14, 2014 8:42 pm
Sounds like the plates are rusted together in which case even if you do get it to free up it will wear out in no time flat. Plan on fixing it.
4Back to top Go down   Clutch disengage Empty Re: Clutch disengage Sun Jun 15, 2014 2:49 am
jlmk100
jlmk100
Thanks for the input will need a strip and clean up when I split the cases.
