1Back to top Go down   Tire sizes Empty Tire sizes Wed Jun 04, 2014 7:15 am
87m6chris
87m6chris
On my 1990 K75 I have a 100/90-18 tire on the front and a
130/90-B17 on the rear, even though they are only 6 yrs old the side walls are starting to crack so I'm going to replace them.
Just wondering if I have to stick with these exact sizes or if I change them a bit like you can do with car tires?
Thanks,
Chris
2Back to top Go down   Tire sizes Empty Re: Tire sizes Wed Jun 04, 2014 7:28 am
100/90-18 or 110/80-18 front
130/90-17 or 140/80-17 rear
The 110F/140R combination was used on some of the later RSs on the same sized rims.  With the larger sizes you might be able to move to radial tyres.
'93 K1100LT
Tire sizes K-dogs10
3Back to top Go down   Tire sizes Empty Re: Tire sizes Wed Jun 04, 2014 12:56 pm
k75RT Keith
k75RT Keith
You can go up 1 size front and rear and they will still fit.  Your bigger limitation is the 2.5" / 2.75" rims that limit what you can fit on the rim
4Back to top Go down   Tire sizes Empty Re: Tire sizes Sat Jun 07, 2014 6:45 pm
87m6chris
87m6chris
Thanks Gents,  not many tires in our sizes anymore.
I'm thinking about this combo,
http://www.fsmotorcycle.com/tires/sport-tires/pirelli-sport-demon.html
Anyone using these?
Thanks,
Chris
5Back to top Go down   Tire sizes Empty Re: Tire sizes Sat Jun 07, 2014 8:33 pm
AL-58 wrote:100/90-18 or 110/80-18 front
Will the lower aspect ratio front (110/80) end up with a smaller overall wheel diameter than with the 100/90?  I've problems with my front Avon 100/90 tire almost hitting the fender; I have barely 5mm clearance, even with spacer washers to raise the fork cross brace (K1100 Marzocchi stanchions). I have K1100 3-spoke 3X18 front rim so tire selection would be more varied than the K100 snowflake rims.
6Back to top Go down   Tire sizes Empty Re: Tire sizes Sat Jun 07, 2014 9:21 pm
87m6chris wrote:Thanks Gents,  not many tires in our sizes anymore.
Anyone using these?
Thanks,
Chris
they work great chris
quite a few members have them on....road surfacing compounds differ across our country's  so you might find different wear rates and expected killometers- miles out of them
rob the lower profile does give a little more clearance
i notice that with the 140 on the back ( or even the 160 on the wide rim ) im doing 4100 at 100 kph ....where as with the 130 x 90  im doing 4k for 100 kph ...if that helps any (still confuses me though )
additionally i have slightly more lift off the ground on the centre stand with the wider profile tyres ....with the 90 sizes both wheels touch the ground ...just ...;.so just a bit of difference in overall diameters
hope that helps
7Back to top Go down   Tire sizes Empty Re: Tire sizes Sun Jun 08, 2014 5:32 am
90% of 100mm = 90mm tyre height
80% of 110mm = 88mm tyre height
There's not much in it.
'93 K1100LT
Tire sizes K-dogs10
