51 Re: '88 K100RT mutilation Sat Sep 27, 2014 8:27 am
HeikkiL
Some hipster decoration for summer room...
Guess original meter panel will do when I drop it as low as possible.
Go to page : 1, 2
I was just going to ask the same question. The fairing on this bike looks GREATAJ.Valente wrote:I'm still not understanding why BMW didn't consider a 1/4 faring on the K100. What, too sporty? Reserved for sport bikes only? :bball:
What about the quarter faring from the R90s OR R100s of the 70s or early 80s? They look great, provide the necessary cover for instruments, etc. and are functional. Not that the solution here is any better or worse, just that with all the manifestations of sprint fairings, sporty farings, etc. for the early K bikes--why is there no 1/4 faring for project bikes as this. Go figure.
Thanks for that Much appreciated infofloyd wrote:Be made wrote:as I understand it the only thing giving a bit of trouble now and then is intermittent speedometer which can be fixed if need beHeikkiL wrote:Guess original instruments will do . ..
Also, the little plastic gears that drive the odometer and trip meter tend to disintegrate. Replacements can be found.
Once again . . much appreciated. I would never have known otherwise . . . thanksduck wrote:And if you leave a K out in the hot sun for extended periods of time then the faceplates (since they're black and adsorb heat) will warp causing the needles to stick.
I figured out an easy fix for this though - pull "the guts" out and then out put some spacers in the upper inner corners of the faceplates to push them back down.
Be made wrote:I was just going to ask the same question. The fairing on this bike looks GREATAJ.Valente wrote:I'm still not understanding why BMW didn't consider a 1/4 faring on the K100. What, too sporty? Reserved for sport bikes only? :bball:
Mossy1200 wrote:Idd like to know what tires you have on it.
hmmm . . . I assume you realize you will get a lot of flickup off the road onto the engine, maybe even as high as the radiator. If me I would be keeping the back edge of the wheel covered. . . . Just a thoughtHeikkiL wrote:
Guess there has to be a front fender also (Not 100% dry and sunny up here... Plus the law also requires one). Bought one from eBay and seems like a good one - of course alloy mudguard would be nicer, but the price tag of a plastic one (ok; a GRP one) was much, much easier to explain to Missus. Much smaller, prettier and lighter than original one.
Be made wrote:hmmm . . . I assume you realize you will get a lot of flickup off the road onto the engine, maybe even as high as the radiator. If me I would be keeping the back edge of the wheel covered. . . . Just a thought
eBay (one available... )Mossy1200 wrote:You better give me the link for that guard.
I like it more than mine and im saving for my paint job at the moment.
If they post to NZ I might be tempted to grab one.
I have watch listed it.HeikkiL wrote:eBay (one available... )Mossy1200 wrote:You better give me the link for that guard.
Yep . . . as I said man . . . JUst a thought. Good luck with the buildHeikkiL wrote:Be made wrote:hmmm . . . I assume you realize you will get a lot of flickup off the road onto the engine, maybe even as high as the radiator. If me I would be keeping the back edge of the wheel covered. . . . Just a thought
Well if my priority was protection against natural elements, I wouldn't have ditched the RT fairing at all. And if you think the front is a bit "too open", wait for the rear part...
This K bike is meant for those sunny and dry summer days for twisty back roads, not as an all-rounder (I guess my back will be happy for that also). For those not-so-perfect days I have an F650 Funduro. With Fenda Extenda even.
HeikkiL wrote:
Tarozzi fork brace - like straight from the '80s...
HeikkiL wrote:Mossy1200 wrote:Idd like to know what tires you have on it.
The tyres are Michelin's Pilot Actives. Dunno if any good - the tyre shop just had them in stock...
Go to page : 1, 2
Similar topics
