1 Fork Oil Change Wed Apr 30, 2014 1:00 am
G'day Fellow K Riders, Sorry but this topic has been covered before but clarification is needed.The Munich Motorcycles handbook says the amount of oil in a K75S (93 model) is 330ml each leg.The Haynes manual says 280ml is the required quantity for a model with the 'S' suspension. When the oil was pumped out using Rickmeister "sucker', the quantity was 280ml. The suspension seemed a bit on the soft side.
Thank you in advance for your words of wisdom. Cheers Tom
