grantf2
grantf2
There seems to be a bit of debate as to if you should lubricate new oil seals before fitment, what is the current school of thought on this?
I am about to replace the large output oil seal on my '84 K100RS and want/need to get it right.
K100RS 1984
With a new OEM you should soak them in engine oil for 2 hours before fitting.  If you haven't got a genuine I hope you bought a Viton (brown) seal. I always oil a seal before using.
grantf2
grantf2
I only use genuine seals.
Thanks for that, I'll give them a good oil bath before fitment.
K100RS 1984
zonenfeile
zonenfeile
if the gearbox & clutch is out:  yes!
the maincourse for leakage is mostly not the big seal but the O-Ring pos 11 19x4 behind the clutch
Should you lube new oil seals before fitting? 4
and if you´ve got it apart anyway:
change the "bitch" seal for cluch pos 12
Should you lube new oil seals before fitting? 3
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
grantf2
grantf2
Sorry for the confusion, I'm only changing the leaking rear diff seal.
K100RS 1984
When I done my final drive seal I did NOT soak in oil but I did put it in the freezer a couple of days before, it poped in easy.
With the exception of the OEM seals with a teflon lip (which have been used mostly as engine seals for around the last two decades) which mostly should be mounted dry.
It have been different submanufacturers of these during the years, from some it have also been printed on the seals that they should be mounted dry.
billtr96sn
billtr96sn
The days of pre soaking oil seals went out with cork seals that needed swelling before they would seal. Modern seals (in the last 40years) do not need soaking as their materials are impervious to oil and that is how they keep it in place, apart from the lip on the shaft of course.
Something witty is supposed to go here... help!! Should you lube new oil seals before fitting? Uk-log10
http://www.billsbikechat.co.uk
From someone who has probably mounted more seals than I've had hot meals Follow the manufacturers instructions, if there is none which is quite common then I mount them without soaking but ALWAYS put a thin smear of lube on the seal lip and shaft surface to prevent the lip overheating from dry friction and burn the lip before the machine can supply oil to it.
Just an oily finger run around the seal will do the job you don't need to dip them in the oil can.
