1 Tyre Fitting Lube Tue Jun 11, 2024 10:50 pm
redrockmania
Tyre Fitting Lube discussions run the risk in morphing into the dreaded oil thread... however. Apart from commercial tyre lube (quite a large number of brands) people have over time report using explosions [see YouTube crazy videos], Windex, WD40, Rubber Grease, KY Gel, Hand sanitiser, silicone grease oil spray, Dishwashing liquid and plenty of other products. A number of products over time risk damaging wheel alloy and/or tyre rubber, so do your research.
Several years ago I purchased a 5 litre tub of commercial tyre lube which is in a paste form, however I found the paste as well of a lot of other products tend to increasingly dry out as tyre fitting progresses which reduces the slippery lubrication needed to assist fitting the tyre. After a lot of research on forums I found a recommendation to use Canola Oil in an aerosol can. A can is less than $4, lasts for ages and applied by spraying gives fast, thorough and accurate coverage. Aerosol application gets the lube into tight spaces, useful when trying to seat a resistant tyre bead.
I've found the Canola (vegetable cooking oil) stays slippery for the duration of a tyre fitting, thus achieving its purpose. It does not damage alloy or rubber and can be washed off with water after scrubbing with detergent.
Hope this helps on this slippery topic
