1 Front master cylinder on long time stood bike Wed 05 Jun 2024, 10:07
Rik lancs
Having just got a k100rs running after being stood in a dry British garage for 14 years my next issue is the front brake
The lever goes in with no pressure
Is it possible that a bleed might sort it out
Or a master cylinder kit
I have 4 days before I can work on it again and should I just order a kit or is it worth trying to bleed it first the rear one seems to work
I dont suppose you guys were to start for the other problem the hazards keep flashing if I mess with the switch I can turn them off temporarily
Iv sprayed the switch with wd 40 but no improvement
