1Back to top Go down   Fork Oil Change Empty Fork Oil Change Wed Apr 30, 2014 1:00 am
G'day Fellow K Riders, Sorry but this topic has been covered before but clarification is needed.The Munich Motorcycles handbook says the amount of oil in a K75S (93 model) is 330ml each leg.The Haynes manual says 280ml is the required quantity for a model with the 'S' suspension. When the oil was pumped out using Rickmeister "sucker', the quantity was 280ml. The suspension seemed a bit on the soft side.
Thank you in advance for your words of wisdom. Cheers Tom
2Back to top Go down   Fork Oil Change Empty Re: Fork Oil Change Wed Apr 30, 2014 1:23 am
Tom,
I knew I had seen this somewhere recently.
FORK OIL
and THIS recent thread.
3Back to top Go down   Fork Oil Change Empty Re: Fork Oil Change Wed Apr 30, 2014 1:41 am
93 = Showa = 410 per side
Be careful not to over-tighten the drain bolts when them putting it back in.  9 Nm.  They will strip the threads in the fork lower if you use too much torque.
4Back to top Go down   Fork Oil Change Empty Re: Fork Oil Change Wed Apr 30, 2014 2:52 am
Fork Oil Change Fork_o10
5Back to top Go down   Fork Oil Change Empty Fork Oil Change Wed Apr 30, 2014 3:00 am
Thanks for the table Rick. 410ml is firmly etched into my senior's brain...
Also spoke to Munich in Perth who were not aware that Showa forks were in use.  Cheers Tom
6Back to top Go down   Fork Oil Change Empty Re: Fork Oil Change Wed Apr 30, 2014 3:40 am
Make sure you check for the "S" stamped into the top plug on the forks. If you put 410ml in an "S" fork it will rattle your teeth out.
7Back to top Go down   Fork Oil Change Empty Fork Oil Change Wed Apr 30, 2014 4:43 am
Thanks Rick, could not see an 'S' stamp/mark anywhere on the top of the forks.Just pushing them up and down with wheel locked seemed to be huge improvement.Cheers TomFork Oil Change Icon_lol
8Back to top Go down   Fork Oil Change Empty Re: Fork Oil Change Wed Apr 30, 2014 8:12 am
Small thread hijack:  Rick's table above says 350/400 for K1100 forks and 400/400 if disassembled.  I took the forks off my bike and fully emptied them by turning upside down and letting them drain.  But I didn't totally disassemble them.  Does that count as "disassembled" for the purpose of refilling?
9Back to top Go down   Fork Oil Change Empty Re: Fork Oil Change Wed Apr 30, 2014 8:56 am
I cant help with that mainly because I cant remember what they looked like from when I had mine apart.
