1Back to top Go down   help starting issues Empty help starting issues Sun Mar 23, 2014 10:52 pm
megamike2193
megamike2193
I have a 8v k100 that will start but barely ticks over and as soon as you try to rev it cuts out
getting fuel but spark seems weak tested resistance of leads getting the normal 5k ohms but one is reading 103k ohms!!!!!!! so obviously this one is bad but would this be enough to cause these issues I suffering im going to test coils later and chase back issue I will buy some new ht leads and plugs anyway but would really like to nail this on the head anyone any tips advice I would really appreciate anything:-)
mike
2Back to top Go down   help starting issues Empty Re: help starting issues Sun Mar 23, 2014 11:08 pm
When you find a problem fix it as that will eliminate that part of the equation. These engines use a wasted spark system in that the plug also fires on the top of the exhaust stroke and as a result a bad lead will affect two cylinders because one coil serves two cylinders.
It could well be the problem but (and isn't there always a but) air leaks in the intake system is a very real possibility as well. Fix the plug lead then if it still is cactus have a look for leaks.
3Back to top Go down   help starting issues Empty Re: help starting issues Sun Mar 23, 2014 11:14 pm
megamike2193
megamike2193
yes had a good look for them although some of the rubbers are going to need doing soon theres nothing leaking as yet I even tried running and spray all dodgy looking areas with wd spray to seal to see if engine picked up but nothing
so will try new plugs and leads and go from there
mike
4Back to top Go down   help starting issues Empty Re: help starting issues Thu Mar 27, 2014 1:45 am
megamike2193
megamike2193
well I thought I fixed 103k ohms on one lead dragging spark down put new lead on fired up great and ran fine
2 days later come to start same problem re checked this lead and is ok now but same issue!!!!!!!!
is coil issue?????
5Back to top Go down   help starting issues Empty Re: help starting issues Thu Mar 27, 2014 1:51 am
k75RT Keith
k75RT Keith
More than likely.  Lead shouldn't fail in days.
6Back to top Go down   help starting issues Empty Re: help starting issues Thu Mar 27, 2014 2:04 am
megamike2193
megamike2193
lead reading fine now but still same barely starts and wont rev.
last time I cut off suppressor cap and just held ht lead close to spark plug and started and ran fine but tried that again this time but doesn't work now!!!!!!
wish I had some spares one to check but might just have to bite bullet and get some newer tested ones
mike
7Back to top Go down   help starting issues Empty Re: help starting issues Thu Mar 27, 2014 2:23 am
um ...you didn't think to change the plugs ?
8Back to top Go down   help starting issues Empty Re: help starting issues Thu Mar 27, 2014 3:07 am
I had something funny with the LT quite a while back, not so long after a full service. Turned out a dud plug, didn't even do 2,000 miles. They are cheap and seemingly given to failing so I now always carry a spare. The old test of fire it up and see which exhaust doesn't get hot.......Swapped plugs on the first step to see was it going to be coil or plug lead, was a dud plug.
9Back to top Go down   help starting issues Empty Re: help starting issues Thu Mar 27, 2014 4:37 am
megamike2193
megamike2193
that's one of the first things I did hadn't it in past on other bikes once you flood them never the same again
I tried it again earlier and hey presto it was fine took it out for run didn't miss a beat will try again over next few days these are the worst problems to diagnose when they don't always do it!!!!
definatly something to do with spark as when it does it the plugs do get wet and when it does go it clears them with a run not like its running rich
mike
10Back to top Go down   help starting issues Empty Re: help starting issues Fri Mar 28, 2014 11:16 pm
megamike2193
megamike2193
Well bike was starting/running fine left it till next day same issues!!! Has anyone had similar issues with hall effect sensor or engine temp sensor????? Really got me baffled this one!!!!
11Back to top Go down   help starting issues Empty Re: help starting issues Sat Mar 29, 2014 12:02 am
Garyk100
Garyk100
I had something similar a few years ago, bike would start but miss badly when you tryed to ride it, new set of leads did not fix it. Turned out to be the fuel filter, changed it and runs well, I put a piece of tube where the filter was, eliminating the filter, it run well, so I bought a new filter, all fixed. Worth a try, cheers Gary
