1Back to top Go down   K1100 top box Empty K1100 top box Thu Mar 06, 2014 6:44 am
malcoops
malcoops
So in trolling through evil bay lately I see a kl1100lt with a larger rear top box.
I original is great for around town etc but the larger box would give me more space for essential travelling items like bottles of red,esky etcetc.
Can anyone shed a bit of light on this subject
I have searched evil bay uk and there are some BMW top boxs which fit this category but at the prices there asking I would be better off selling body parts to try and raise the mulla
Thanks again
Mal
Laugh and Laugh Often
bmw kl1100lt, 1993, honda cx500 1978, honda gl500 1982, and bits and pieces
2Back to top Go down   K1100 top box Empty Re: K1100 top box Thu Mar 06, 2014 7:15 am
Mal,
From what I'v found out, the small top box fits to the small rear grill/rack on the tail section but the large box needs the mounting frame which bolts to the mounting points on the side of the bike where the pannier mounts attach. That would be part 9 and 10 in this image.
K1100 top box B0001124
I have bought one of these -> http://www.ebay.com.au/itm/Oxford-Universal-Top-Box-44-litres-/190781412223?pt=AU_Motorcycle_Parts_Accessories&hash=item2c6b75537f&_uhb=1
I hope to make a rack and rail assembly to mount it's mounting plate to the back of the bike.
3Back to top Go down   K1100 top box Empty Re: K1100 top box Fri Mar 07, 2014 4:38 am
malcoops
malcoops
thanks robin.
I do have accès to some métal work materials/equipment and Im now thinking about making a larger aluminium box for the rear carrier myself,that way I can make whatever size I like.
4Back to top Go down   K1100 top box Empty Re: K1100 top box Fri Mar 07, 2014 5:09 am
Robin ,my recent experience with the 1100LT bracketing as you have posted , was a lot of sideways wobble.
they have generous capacity, but be wary of loading them up like an esky. Mal you may be in for another shock, should you choose this style.
the main weakness is that they are relatively flexible plastic frames and this is exaggerated by heavier loading.
good luck with alternate materials.
if anything secure bracing from the usual four hole point in the cowl seems to be effective .
K1100 top box 10_x_110
5Back to top Go down   K1100 top box Empty Re: K1100 top box Fri Mar 07, 2014 7:42 am
I wonder if they still make gearsack racks these days, they had instant street cred, if I could spell ubiquitis then i'd use it.
6Back to top Go down   K1100 top box Empty Re: K1100 top box Fri Mar 07, 2014 9:10 am
Saw a couple of the original top boxes on US fleabay for a very reasonable $600 approx.
7Back to top Go down   K1100 top box Empty Re: K1100 top box Sun Mar 09, 2014 5:37 am
malcoops
malcoops
My rack has already been modified to strengthen it but it needs more
I will not be loading it up esky like but to give me some more cruising flexibility
I have some thoughts I will share as I progress
8Back to top Go down   K1100 top box Empty Re: K1100 top box Sun Mar 09, 2014 6:01 am
If its the black plastic rack surely some 6mm alloy flat bar shaped to fit it snugly would carry half the planet, some times they only need a minimum of support
9Back to top Go down   K1100 top box Empty Re: K1100 top box Sun Mar 09, 2014 12:27 pm
groverK wrote:Robin ,my recent experience with the 1100LT bracketing as you have posted , was a lot of sideways wobble.
I've never had a KBike with a rear rack before but I bought a complete rack off ebay tonight so we shall see. If you look at the fische for the RBikes, they have a pair of steel rods that bolt to the top of the frame, poke out the back of the tail and connect to the rack. That monsterous rear box on my R-RT can hold a mountain of heavy stuff without issue. You seem able to just keep sticking stuff into it. The KBike rear rack might benefit from something similar.
K1100 top box B0003387
