1Back to top Go down   Screen fixing Empty Screen fixing Thu Feb 06, 2014 10:51 pm
Johnser
Johnser
Hello!
Just bought a new flip up screen for my naked k100;
Screen fixing BMW-K75C-TALL1-225x300
http://www.flowrideruk.co.uk/product/bmw-k75c-flip-up-tall-screen/
I'm pretty pleased with the screen and went for a light grey instead of the stock (almost) black/brown that was on the bike. There's a good chance there will be some hiding going on in the rain and it'd be nice to be able to see through it...
The mounting holes on the screen don't match the body perfectly. I'd rather not drill the body out to get things re-alligned in case I (or someone else) decides to go back to stock. So that rules out something like these:
Screen fixing $(KGrHqRHJEEFH,sK1ZMnBR+2-wobpQ~~60_12
Unless I put the bolt heads on the inside... but that would look odd even by my standards.
So I could do with an M5 bolt with a larger head that will cover the larger holes I will have to drill in the screen. Preferably with some vibration cushioning and while I could get creative with my crappy lathe, preferably off the shelf....
any thoughts? I think I can do better than gutter bolts and tap washers!
2Back to top Go down   Screen fixing Empty Re: Screen fixing Thu Feb 06, 2014 10:53 pm
Johnser
Johnser
3Back to top Go down   Screen fixing Empty Re: Screen fixing Sat Feb 08, 2014 3:07 pm
Oma Aika
Oma Aika
I bought a screen for my K75 and an other for my CX500 from the same place! Price/quality is good!
More: http://www.vanhamoto.net/2013/07/plekseja-saa-vanhoihinkin-pyoriin.html - 3 pics and a story (but in Finnish, use the Translate butter on upper right corner of that page)
New and the original:
Screen fixing IMG_5419_800
Honda CX 500 -81 & BMW K75 -89
Blog www.vanhamoto.net (in Finnish but there is a translator on the pages)
Only pictures: http://www.vanhamoto.net/p/kuvia.html
4Back to top Go down   Screen fixing Empty Re: Screen fixing Sat Feb 08, 2014 3:18 pm
Johnser
Johnser
Thanks.. I see they used your picture on their facebook page (I was hunting for discount codes!)
I have had to trim my screen, alter a hole and melt/bend the corners to persuade it to fit nicely. So I wont be screaming from the rooftops about the quality.
But it does seem a decent screen. The fixing kit I posted above will be fine - it arrived this morning.
5Back to top Go down   Screen fixing Empty Re: Screen fixing Sat Feb 08, 2014 3:23 pm
How tall is it?
Screen fixing K75cflowrider
6Back to top Go down   Screen fixing Empty Re: Screen fixing Sat Feb 08, 2014 3:36 pm
7Back to top Go down   Screen fixing Empty Re: Screen fixing Sat Feb 08, 2014 3:39 pm
40.5cm - 16"
8Back to top Go down   Screen fixing Empty Re: Screen fixing Sat Feb 08, 2014 5:32 pm
Johnser
Johnser
I dont know if that measurement is the height when fitted or the length of the screen. I'll try remember to take a pic when its fitted if you like
9Back to top Go down   Screen fixing Empty Re: Screen fixing Sat Feb 08, 2014 6:40 pm
I'd be interested in both side and front pics.  My turbo K75 has a C fairing w/ a Laminar Lip. A one piece option might be nice.
10Back to top Go down   Screen fixing Empty Re: Screen fixing Sun Feb 09, 2014 2:24 am
Brad-Man
Brad-Man
I have a C fairing that I will need a screen for - this may be just the thing - Thanks!
11Back to top Go down   Screen fixing Empty Re: Screen fixing Sat Mar 08, 2014 8:26 pm
Johnser
Johnser
Pics for those asking
Screen fixing 101_1754_zps570221d2
Screen fixing 101_1752_zps5ce78d4e
Took it out for a ride today. To be honest it was so long ago I rode it, I forget what the original screen was like. Playing around in the wind it seems to offer a fair bit of protection for your body and a good bit of the helmet. Its not impossible to see through if you duck down onto the tank. At 100 (lets say kph) the jet of air hits my hat just above the visor.
The only question I'd have is regarding the strength of the supports for the fairing. I had to shim mine out a bit around the stanchions with a bit of inner tube (the whole assembly basically clamps to the stanchions between the yolks) as without, there would have been a lot of play.
Also had to trim the screen slightly to fit and heat the tips a bit to bend them in slightly to better match the curve of the nacelle. needed repainting where the original screen had rubbed too.
