Number of posts : 4445
What I usually do on my bikes is replace the OEM flasher relay with a Kisan SignalMinder SM-6.
This has several advantages:
1 - It's LED "friendly" right out of the box.
2 - The auto-cancel is timed (I have it set to 45 sec) which I prefer to the way the OEM auto-cancel works. When the brakes are applied (like at a stop light) it pauses the timing of the auto-cancel.
3 - The turn signal paddles work as on and off switches. Hit a signal once, it comes on. Hit it again, it turns off. So, although the regular cancel button works if you want to use it, you don't need to.
