1Back to top Go down   Rear Shock Substitution.   Empty Rear Shock Substitution. Fri Dec 13, 2013 7:28 pm
tio Jaimito
tio Jaimito
Greetings fellow brickers,   Happy Holidays to all.
I am guessing that the K1100 shock  will add some weight capacity  to the K75, since there is a weight difference.  (1100 is heavier than 75)
Thanks for your thoughts.
Jim
Krazy Kat. 1985 K100RS Alaskablau 13000miles 8valve "Black Belly"
Peggy's 1987 K75s Columbia Grey 9500miles 6 valve.
Rear Shock Substitution.   K100_m12
Rear Shock Substitution.   K75_po12
Rear Shock Substitution.   Basil_10
http://www.nachicagonorth.com
2Back to top Go down   Rear Shock Substitution.   Empty Re: Rear Shock Substitution. Fri Dec 13, 2013 7:34 pm
The K11 shock is also longer than the one used on the K75, due to the paralever.
3Back to top Go down   Rear Shock Substitution.   Empty Re: Rear Shock Substitution. Fri Dec 13, 2013 8:07 pm
And it doesn't have quite as much travel (8mm).
Is it for the extra load you want this setup?
Maybe a slight increase in spring size would do the trick.
4Back to top Go down   Rear Shock Substitution.   Empty Re: Rear Shock Substitution. Fri Dec 13, 2013 8:20 pm
tio Jaimito
tio Jaimito
Thanks gentlemen, There are a number of problems:   the principal one on this thread is that the stock k75 shock won't handle two large adults on it's heaviest setting.
Other issues at hand are the 120/70/17 rear tire, and lowered Corbin from Previous Owner.    I am 6'6" tall and 200lbs and mama is 5'9" and 140, we have bottomed out on modest bumps.      I am changing rear tire to 140/80/17 Avon and the seat is on the block also.
I was just wondering if the 1100 shock was a viable option.   I don't mind a stiffer ride but the lack of travel is worrying me.
UJ
5Back to top Go down   Rear Shock Substitution.   Empty Re: Rear Shock Substitution. Fri Dec 13, 2013 8:37 pm
An 1100 shock wont solve the problem, I reckon you will need to go to a stronger spring or possibly a complete new shock where you can adjust the spring tension for the load. The RAM SHOX from Realm Engineering in UK would do the job and I think he would do a stiffer spring as well.
http://www.realmengineering.com/page15.html
6Back to top Go down   Rear Shock Substitution.   Empty Re: Rear Shock Substitution. Fri Dec 13, 2013 8:47 pm
MikeP
MikeP
At RAM, they'll ask you weights of rider & pillion plus use, ie laden or not and recommend a suitable spring.
1992 K1
7Back to top Go down   Rear Shock Substitution.   Empty just wrote them. Fri Dec 13, 2013 11:09 pm
tio Jaimito
tio Jaimito
Thanks guys,   I just wrote Realm.  I noticed that the "high performance" shock is "shorter".  Perhaps there is a good reason for it to be shorter.  Taller would suit me better.    I will wait for them to answer and report what they say.   I appreciate your quick help.   So I will give them a try on your sage advice.  Smile
Uj
8Back to top Go down   Rear Shock Substitution.   Empty Re: Rear Shock Substitution. Fri Dec 13, 2013 11:52 pm
keeper
I just bought a Realm shock for the 100. They were great to deal with, very prompt, helpful, and a really nice looking unit.
Ralph
Every day is a new adventure.
1987 K100RS; 1978 Yamaha TY175 (trials)
9Back to top Go down   Rear Shock Substitution.   Empty Re: Rear Shock Substitution. Sat Dec 14, 2013 9:10 am
ReneZ
ReneZ
I have a Realm shock on my K100. I got the 1100 version to gain a bit of height (I'm 6'5"). I have not noticed any issue with reduced travel, not even with a pillion and full luggage.
Rene
BMW K100 - 1985 (0030029) Scotland Rear Shock Substitution.   Rain
