1Back to top Go down   Luftmeister Exhust tuning  Empty Luftmeister Exhust tuning Wed Dec 11, 2013 4:14 pm
KTRacer
KTRacer
hello everyone, I just picked up this luftmeister 4 into 1 exhaust off ebay. It needs some refinishing, but over all its in nice shape. So my question is, will I have to do any tuning or can a bolt this mamajama on and go? If I do have to do some tuning do I just re-balance the idle? I was told you really cant tune these engines under a load with out doing it on a bench. Here is a link to the exhaust. any in formation will help!
http://www.ebay.com/itm/261347003948?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
http://www.coroflot.com/kjtrester80
2Back to top Go down   Luftmeister Exhust tuning  Empty Re: Luftmeister Exhust tuning Wed Dec 11, 2013 4:29 pm
put it on run it and see....if you are concerned just kill the engine mid run and pull a plug to check the mixture and adjust at the AFM if necessary which I doubt will be am issue. I have only ever put on one after market "Zorst" which needed rejetting and this was only one increment richer.
looks great and should sound amazing....
KKlompy Luftmeister Exhust tuning  2854237993
Luftmeister Exhust tuning  Au-log10
3Back to top Go down   Luftmeister Exhust tuning  Empty Re: Luftmeister Exhust tuning Wed Dec 11, 2013 9:11 pm
KTRacer
KTRacer
Ok, this maybe a stupid question. So if I have to make it richer, how do I re jet a k100?
4Back to top Go down   Luftmeister Exhust tuning  Empty Re: Luftmeister Exhust tuning Wed Dec 11, 2013 9:37 pm
I sincerely doubt that this is an issue worth worrying about.  I have a Lufty on a K100 - works fine.
5Back to top Go down   Luftmeister Exhust tuning  Empty Re: Luftmeister Exhust tuning Wed Dec 11, 2013 11:58 pm
KTRacer wrote:Ok, this maybe a stupid question. So if I have to make it richer, how do I re jet a k100?
The way the Fuel injection is set up it is to a large degree self correcting as it delivers the correct fuel acording to the volume of air passed the Maf sensor.
If you started using the FI on a much bigger engine then it would start to get confused but not with the small quantity of extra air that good pipes let through, if indeed they do.
6Back to top Go down   Luftmeister Exhust tuning  Empty Re: Luftmeister Exhust tuning Thu Dec 12, 2013 3:46 pm
KTRacer
KTRacer
Awesome thanks everyone!
