1Back to top Go down   Stubborn Fork Bolt Empty Stubborn Fork Bolt Mon May 19, 2014 2:25 pm
GeorgiaK
GeorgiaK
I'm installing new headlight brackets that slide on over the fork tubes. I'm trying to remove the top fork support bar so I can slide these things on. Assuming I'm targeting the correct bolts, they are not budging. Save me, oh K bike brothers.
Stubborn Fork Bolt Photo-17
I've tried uploading this photo a bajillion times and it always uploads rotated wrong. Same thing with photos I tried posting yesterday. 💣
1990 K100LT
2Back to top Go down   Stubborn Fork Bolt Empty Re: Stubborn Fork Bolt Mon May 19, 2014 2:35 pm
Kyle10
Kyle10
First thing, get your bike off its side  🐰
Get a bottle of Marv. Mystery Oil and a can of acetone. Mix 50/50. Apply it to the bolts and leave it, overnight if possible. The best penetrating oil you can get.
And gawd do not make a hash out of the bolt hex. It's easy to do and hell to rectify. Aluminum can, does 'weld' to other metals given time and conditions. This could be what you're dealing with.
1985 K100rt 0052183
1983 Honda VF750 007713
3Back to top Go down   Stubborn Fork Bolt Empty Re: Stubborn Fork Bolt Mon May 19, 2014 2:47 pm
Sometimes, giving a good blow with a hammer on the head of the screw will help "unseizing" the thread.
After that it will be easier for the penetrating oil to clear the corrosion.
CF
Stubborn Fork Bolt Frog15Stubborn Fork Bolt Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   Stubborn Fork Bolt Empty Re: Stubborn Fork Bolt Mon May 19, 2014 2:51 pm
GeorgiaK
GeorgiaK
Ordered the penetrating oils and will give it a go. I was definitely afraid of stripping this thing out, that's why I came to y'all.
CF, Ah! Yes! I've used this trick before. I'll give it a shot along with the penetrating oil.
1990 K100LT
5Back to top Go down   Stubborn Fork Bolt Empty Re: Stubborn Fork Bolt Mon May 19, 2014 3:15 pm
xpc316e
xpc316e
Get a small asbestos mat from a plumbers' merchant to shield the wires and cables and get some heat on that sucker.
When you do get it out make sure it is replaced by a socket head screw of normal depth.  For some crazy reason these bolts have a shallow head for the Allen key to locate into.  Couple that with their tendency to seize and you have a problem.
6Back to top Go down   Stubborn Fork Bolt Empty Re: Stubborn Fork Bolt Thu May 22, 2014 1:55 am
GeorgiaK
GeorgiaK
I applied the penetrating oil/acetone mix with no success. I just applied it with a rag and let it sit most of the day. Is there any trick to applying it?
Last resort is getting my torch out.
1990 K100LT
7Back to top Go down   Stubborn Fork Bolt Empty Re: Stubborn Fork Bolt Thu May 22, 2014 2:05 am
I know that this is a last resort thing but peining the alloy around the bolt with a 12oz ball pein hammer can make the corrosion let go as well it also makes the surface dimpled but I reckon that at this stage getting the bolt out is the aim.
I have a set of old allen keys that are now just a straight shaft and a set of small ring spanners that fit each size down to 5mm (stahlwille) and put the key in the head of the bolt with the ring spanner on the key then pound the end of the key and apply some pressure to undo at the same time. Don't be afraid to pound it hard as the only thing that you will damage is the old allen key and they are plentiful.
8Back to top Go down   Stubborn Fork Bolt Empty Re: Stubborn Fork Bolt Thu May 22, 2014 3:23 am
JGT
JGT
When you do manage to remove it, replace both upper and lower ones with hex bolts. You will need a couple of additional washers on the lower bolts to enable the hexagon to clear the counter sunk holes. Don't forget to lube them! John
1992 K75
9Back to top Go down   Stubborn Fork Bolt Empty Re: Stubborn Fork Bolt Wed Jun 04, 2014 3:09 pm
GeorgiaK
GeorgiaK
After pumping some iron, I was finally able to get those buggers off. Turns out that the penetrating oil mixed with some bigger tools did the trick.   Stubborn Fork Bolt 22936
1990 K100LT
10Back to top Go down   Stubborn Fork Bolt Empty Re: Stubborn Fork Bolt Wed Jun 04, 2014 6:59 pm
two66mhz
two66mhz
xpc316e wrote:Get a small asbestos mat from a plumbers' merchant to shield the wires and cables and get some heat on that sucker.
Asbestos Mat? You still can buy those? Question
