1Back to top Go down   Crash, Bang, Tinkle. Empty Crash, Bang, Tinkle. Sun Oct 13, 2013 9:50 pm
Just a short progress update:
Smithy has been invaluable help with this, with his skills and thinking.
Thanks also to the others, Charlie, RossKo, Blakey, TWB, Klompy...Ed...the list goes on and this list is amazing.
This is the main culprit....looks innocent enough but obviously is worth a few broken ribs etc.
Crash, Bang, Tinkle. Sam_3910
Crash, Bang, Tinkle. Sam_3810
This piece is from the front mounting arm: It was the subject of a roadside repair last year during the long tour. A piece was welded in to further strengthen it. I believe this broke this time as a result of impact, not fatigue.
( Note the weld didn't go all the way around)
Crash, Bang, Tinkle. Sam_3911
Crash, Bang, Tinkle. Sean_s10
We are working under the premise that less flex is better and so more bracing will be employed. I spoke to a few people about this and although it remains a bit of a black art, rigidity seems to be a good thing.
Crash, Bang, Tinkle. Sean_s11
Right then...best get back to the shed. Smile
2Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Sun Oct 13, 2013 10:06 pm
new wheel for the beast  (ex twb )
heading towards guyra
Crash, Bang, Tinkle. 1383161_4798324456213_1454453999_n
3Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Sun Oct 13, 2013 10:16 pm
Smile Smile Smile
4Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Oct 14, 2013 1:46 am
No wonder it broke, it's things like that make my blood run cold.
5Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Oct 14, 2013 4:54 am
 Thinking that's a bit harsh , It might happen,Crash, Bang, Tinkle. 502531 Crash, Bang, Tinkle. 502531  but I'm sure its induced by beer.
6Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Oct 14, 2013 4:58 am
looking good Sean , good to hear the apprentice is working well.
not sure if I'm right here ,but the area of concern for this worry wart is that you still have a frame that will flex .
couldn't get my drawings to work , but to best describe it is , as you look at your frame in the pic draw an imaginary line from 12 o'clock to 6 o'clock  ,
the front foremost weld on the bend , and the weld halfway along the inner side ( nearest the Gearshift) create a weak point .
 ,this area with sufficient force this will bend .
 this could be the origins of the previous break at the front, too much flex .
my thoughts would be to strengthen the front weld with additional tubing inside the existing tube to overlap all new welds.
and because the frame along the inner side nearest the bike is formed in two pieces , brace it with a piece of C section,
 overlapping each side of the weld by a good 8"( 200mm).
just thinking..
top job by all.
Crash, Bang, Tinkle. 10_x_110
7Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Oct 14, 2013 5:52 am
BIG D
BIG D
Cool
Nice work Sean, The thing with stress & fatigue in metal is it moves brace one peice and the point moves to the end of the brace its like when something is welded up usualy its not the weld but the material next to it that breaks, Just me babling on keep up the good work.
BIG D
8Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Tue Oct 15, 2013 1:27 am
Let me rephrase this.....
Smithy is doing all the good work, I'm just along for the ride! What a Face What a Face
9Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Oct 28, 2013 6:52 pm
Found one already built Schoorn.
SIDECAR
Crash, Bang, Tinkle. Origin10
10Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Tue Oct 29, 2013 5:17 am
Niiiice. Like his instrument pod!
Crash, Bang, Tinkle. Sam_3912
11Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Tue Oct 29, 2013 5:58 am
Saxon7 wrote:Niiiice. Like his instrument pod!
Hmmmm. Stealth mode?
12Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Sun Nov 03, 2013 4:41 am
The old girl lives!
Much invaluable help from Smithy who is a very handy fellow. Still a little bit of work to re-fit the fuselage but that will be taken care of tomorrow. Smile
Crash, Bang, Tinkle. Sam_4011
Crash, Bang, Tinkle. Img_4010
Happy camper Schoorn.
13Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Sun Nov 03, 2013 6:51 pm
Good to see the progress.
Belle doesn't seem to be much interested Sad
Here is an idea to finish your project..
Crash, Bang, Tinkle. Side_110
What is this beast????
Oh, only a K bike with slight modifications Very Happy
Crash, Bang, Tinkle. Side-110
Crash, Bang, Tinkle. Frog15Crash, Bang, Tinkle. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
14Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Sun Nov 03, 2013 9:13 pm
Wow, you would want to make sure everything was working perfectly before you bolted that beast back together.
'A ride this week? Sorry no, can't go for a ride this week. I forgot to top up the radiator overflow bottle and it will take 3 days to remove the body work.'
15Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Sun Nov 03, 2013 10:28 pm
Ah you see you don't have the radiator overflow bottle in the original position, you can put it somewhere that only takes 4 hours to check and then it would be as easy to work on as a Ferrari
16Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 1:18 am
I like this one for access and cost...
[url=http://www.bikesales.com.au/private/details/honda-ct110p-1999-15396887?R=15396887&keywords=sidecar&__Ntk=BikeAll&__Nne=15&__Dx=mode matchany&__no=0&__D=sidecar&silo=1400&seot=1&__sid=142231C79AE4&__N=1432 604 1430 1626 1429 1626 1428&__ns=p_IsPoa_Int32%7c0%7c%7cp_RankSort_Int32%7c1%7c%7cp_HasPhotos_Int32%7c1%7c%7cp_Make_String%7c0%7c%7cp_Model_String%7c0%7c%7cp_YearMade_Int32%7c1%7c%7cp_PriceSort_Decimal%7c1%7c%7cp_PhotoCount_Int32%7c1&__Qpb=1&__Ntx=mode matchallpartial&cr=1&__Ntt=sidecar&trecs=19]http://www.bikesales.com.au/private/details/honda-ct110p-1999-15396887?R=15396887&keywords=sidecar&__Ntk=BikeAll&__Nne=15&__Dx=mode%20matchany&__No=0&__D=sidecar&silo=1400&seot=1&__sid=142231C79AE4&__N=1432%20604%201430%201626%201429%201626%201428&__Ns=p_IsPoa_Int32%7c0%7c%7cp_RankSort_Int32%7c1%7c%7cp_HasPhotos_Int32%7c1%7c%7cp_Make_String%7c0%7c%7cp_Model_String%7c0%7c%7cp_YearMade_Int32%7c1%7c%7cp_PriceSort_Decimal%7c1%7c%7cp_PhotoCount_Int32%7c1&__Qpb=1&__Ntx=mode%20matchallpartial&Cr=1&__Ntt=sidecar&trecs=19[/url]
KKlompy Crash, Bang, Tinkle. 2854237993
Crash, Bang, Tinkle. Au-log10
17Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 1:26 am
i have that guys contavct details klompy
he even sells a full sized version
18Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 3:36 am
Brief shakedown ride this arvo. Brave Bella jumped in straight away. Bike is running and handling well, feels much more rigid. Also feels pretty ....er...naked ....without the barn door on the front.
Crash, Bang, Tinkle. Sam_4012
Crash, Bang, Tinkle. Sam_4013
19Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 3:52 am
Hey mate that puts a Very Happy  on my face to see you back on the road again, looks like Bella's happy to. Great pics Sean.
         Smithy
20Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 5:08 am
You haven't made a matching naked chair as well have you?
Where is the screen?
21Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 5:20 am
Ghost who rides
Ghost who rides
Well done Sean and Smithy plus the other contributers, great team effort.
PS  I never doubted that Bella would ride again.
22Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 6:50 am
23Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 7:00 pm
Rossko, I keep telling that dog she needs to HTFU. :albino:
24Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 7:27 pm
Saxon7 wrote:Rossko, I keep telling that dog she needs to HTFU. :albino:
Be nice, you are talking to lady Bella.Crash, Bang, Tinkle. Lickin10
25Back to top Go down   Crash, Bang, Tinkle. Empty Re: Crash, Bang, Tinkle. Mon Nov 04, 2013 8:21 pm
affraid Crash, Bang, Tinkle. 44271 Crash, Bang, Tinkle. 44271
