1Back to top Go down   Output shaft bearing Empty Output shaft bearing Thu Feb 20, 2014 6:27 pm
smoll1
Hi everyone
Just putting new bearings on output shaft have later bearing with the shoulder not clip, should I use little bit of bearing fix Loctite on bearing to stop it spinning in the case. I see the genuine manual says use some bearing fix but underneath it also says "do not bond ball bearing with shoulder at its outer race"??? any advice would be great????
Smoll Very Happy  Very Happy  Very Happy  Very Happy
