So, I rebuilt my gear box ….
May I mention that I have NEVER opened, or worked on a gear box before?
In my previous posts I mentioned that; when I got the bike, the PO told me that the bike will ‘sometimes’ jump out of 2nd gear. This ‘sometimes’ proved to be much more regular than reported: in fact, the 2nd gear was all but useless to me. So, you had to rev the hell out of the bike in 1st and then go directly to third to get under way. This worked, but on an incline, the loss of 2nd caused the engine to labor in third; which invariably, fouled the plugs with too much fuel, causing the bike to miss. This left me stranded once – which was more than enough.
Gear box repair was on the list for attention, but later. I had other problems to attend to. But, then I bit the bullet and decided to strip the bike down and repair all the issues in one go.
My list was the following: Repair the rear brake master cylinder. Replace the clutch/gearbox housing rubber boot. Have the fuel injectors serviced and check the fuel delivery system. Do a spline lube (all) and while at it, check the clutch for wear. The starter sprag clutch was also sticking and I planned to pull the bell housing and have a look see. But, with the bike apart, the sprag clutch seems to be working perfectly. I think I will go the high detergent oil route.
If I may be as presumptions as to make a suggestion: Disassemble in sub assemblies. Repair/service sub assemblies and rebuild in sub assemblies. The BMW bike just has too many parts and ‘mix and match’ when reassembling; does not work! As me how I know ….
OK, back to the box: I was fortunate in sourcing a complete box off a K75 in the UK (I am in South Africa.) The donor bike had just over 100,000 miles on it and the seller assured me that this bike (and the box) was in good nick. It was not an accident wreck; but a running bike that was being parted out. The fact that it was a K75 did not really bother me. The small difference in ratios will not; given my riding style, ever bother me.
But, posting a complete box from the UK to here; would have been prohibitively expensive. So, I asked if the seller would be prepared to strip the box into its sub assemblies and then just send the innards to me. I also asked that he photograph all of the parts to be sent, so I could check this against the parts lists in the various manuals. To this he agreed. He would keep the casing in payment of labor and I would still pay the full price as advertised (GB 50 Pounds). UPS charges 63 Pounds and local import fees, VAT etc, added another 12 Pounds to the bill. BTW; the package arrived here in 4 days! Wow! At the same time, I ordered a complete gear box seal kit from Moto Bins, as well as the clutch/box bellows rubber. This is still ‘on the water’.
I had previously stripped the ‘old’ box and made sure to carefully label all the bits and pieces; as well as take lots of photographs. (This is so necessary!)
With the new parts in front of me, it was time to check them for condition. I must say, the seller was true to his word. The replacement parts were all but perfect. The bearings were in a perfect condition. There was no play where play was not to be and one had to look really hard to see any wear marks on the dogs. In fact, my bike had 80 odd thousand kilometers on it and its parts show more wear. Only problem I found was a little rust on some of the main gears; in the valleys between the teeth. Only on a small spot on all of the gears – looks like some water got into the box and pooled where the gears had meshed. This cleaned up with a wire brush and magnified inspection showed no pitting. A good clean and a good lube with assembly oil and the parts were good to go.
Perhaps this is not so much of a ‘rebuild’ as a reassembly. The input, idler and output gear assemblies were not disassembled.
What scared me however; was the end float on all of the gears. I had the shims that came out of the old box and no other. If the end float needed adjusting beyond the shims that I had on hand, I would have had a problem.
First I did, was to measure and compare the OAL of the old sub assemblies against the new. Thankfully, they were exactly the same. Then I re fitted the old sub assemblies in the box and measured the end float on them. Then the new assemblies and thankfully, there was but .001 difference. As this was well within spec., I decided to use the shims I had on hand.
This is amazing and shows the precision with which these boxes are built. To have a K100 and a K75 box out by only .001; is unheard of!
I decided to replace all of the old parts with new; this to accommodate the wear patterns on the sub assemblies. The only ‘old’ parts, apart from the casing; was the neutral indent and the gear change lever. Oh! And a circlip; which I managed to lose one of.
With the seals still ‘somewhere on the water’, I decided to do a test assembly of the box; just to check if I could do it. (BTW, the old seals are still perfect.)
Luckily, I have all the manuals available and these were read, and re read, till I could recite them in my sleep. I also told myself: Use no force!
I bit tricky to get the float and output gear sub assemblies to fit their bearing recesses. I did not use heat and a lot of attempts were fruitless. Individually, they would fit if held just right: but as a group? Wow! Used some layout blue to see if the casings were mating correctly and yes; there were no gaps. Tolerances are incredibly tight. But, I must have done something right because, on the umpteenth try, they just slipped in. I could hardly believe it!
Fitting the forks was another challenge. There is about no space in there and I learned that: the bottom one (large) goes in first; then the small one on the idler shaft and then the medium one on the output shaft. Again, if you do it right, it just slips right in. Oh! And do not lose one of those little ring bearings that fit the selector drum. Went magnet fishing a few times there!
Put the lid on and lightly screwed it down. Ran it through the gears and am happy to say, they select and mesh perfectly.
Now, if only the damn seals would come ….
In the mean time, I bought another bike; a ’77 Goldwing GL1000. Another sadly neglected machine, but it runs well and get’s me from A to B (just). Seems I have a habit of rescuing abused orphans. But, they’re cheap and it keeps me out of mischief.
I will say this: Riding the Goldwing compared to the K100 is like riding a donkey and a race horse!
