Number of posts : 7967
I thought of using the breather but two things, one is that then there is no breather and therefore no vent...vacuum lock plus it will take forever for petrol to run down into the underseat tank unless it has a separate vent which will have to be higher than the fill point. The second thing is that the diameter will mean I need a fill point under the seat, which I prefer not to do because it means pulling out everything ever time it is refuelled.
Maybe combine both, pump through a non return valve to the return line AND use the tank breather. But if I do this how do I get petrol to flow down to the underseat tank - it would need one connection to be at the bottom of the main tank, ie the breather line. Is it feasible to alter the pick up point for the fuel pump by extending the pick up line down into the underseat tank?
Anyway I wont pursue this any more in this post, feels like its hijacking it. I will experiment with some shapes first and see what I can do. I think the best bet will be to make up a stainless steel one on a rubber mounting on the original battery tray and using the battery hold down clamps. Make it in plastic first and when its right get it made up in stainless steel.
1971 Yamaha 125 YAS-1
