1Back to top Go down   She sprung a leak Empty She sprung a leak Mon Oct 28, 2013 4:28 pm
ironbutt
ironbutt
Hey Y'all, Wow its been awhile since I've been here...spent the latter part of the summer in Colorado on a dude ranch ridin 4 hoofs instead of two
wheels...almost as much fun! Then between workin and ridin two wheels as often as I can I haven't been in front of my computer much at all. Well
yesterday after coming back from a nice ride with friends and putting the bike up on the center stand I stepped outside the garage to kiss me bride
and when I turned back to get my helmet I see a stream of gear oil running done the floor. by the time I unsuited and got down to look it had stopped
run out so I'm not sure where it was coming from but near the center stand. :ang:Have to say I have been pushing this old gal pretty hard lately not
wanting these young guys on their crouch rockets to get the best of me. So any ideas what might be going on. I looked thru 19 pages of threads but
came up empty.  Anybody got any wisdom to share?
She sprung a leak 1106080553
85 K100rs WB 1051307F0040102
2010 Camaro SS
2Back to top Go down   She sprung a leak Empty Re: She sprung a leak Mon Oct 28, 2013 4:46 pm
MikeP
MikeP
Most likely culprit is the rubber cover on the clutch pushrod. They do split:
She sprung a leak K1100LT%20%28148%29-M
1992 K1
3Back to top Go down   She sprung a leak Empty Re: She sprung a leak Mon Oct 28, 2013 6:32 pm
club_c
club_c
I had the same thought BTDT (this like a grade school kid agreeing with Einstein)...
1988 K100RS SE VIN 01477554
4Back to top Go down   She sprung a leak Empty She sprunge a leak Tue Oct 29, 2013 2:00 pm
ironbutt
ironbutt
Thanks for the replies ... checked the boot and its dry and in good shape...bout 16mos old. Wish I could take a pic and post but my camera on my phone is dead... will see if I can grab my wife's tonight. Looking up and towards the front of the bike just beyond the center stand bracket is a hole about a 1/4 inch... can't feel any threads but it looks like it might of had a plug of sorts in it... dang wish I could get a pic up for you.
2010 Camaro SS
5Back to top Go down   She sprung a leak Empty Re: She sprung a leak Tue Oct 29, 2013 2:50 pm
ironbutt
ironbutt
While we're on the subject of gear oil...if someone could share the dimensions of the transmission fluid gauge that would be most helpful!
2010 Camaro SS
6Back to top Go down   She sprung a leak Empty Re: She sprung a leak Tue Oct 29, 2013 2:59 pm
MikeP
MikeP
Does this help?
She sprung a leak K1100LT%20%28222%29-L
The hole may be the drain in the centre of the lowest part of the case.
If oil is coming from there it's one of three things:
The clutch shaft O-ring, the output-shaft seal between the clutch carrier and the crankcase or the gearbox input-shaft seal.
None are that hard to fix just a fair bit has to come off to get at them.
Unfortunately you won't know until you get the clutch out but the most likely culprit is the O-ring.
None should cause a catastrophic failure in the short term. The worst is clutch contamination resulting in it slipping.
1992 K1
7Back to top Go down   She sprung a leak Empty Re: She sprung a leak Tue Oct 29, 2013 3:36 pm
ironbutt
ironbutt
Ok going forward on the bike what that whole piece attaches to is where this hole is.
2010 Camaro SS
8Back to top Go down   She sprung a leak Empty Re: She sprung a leak Tue Oct 29, 2013 3:55 pm
ironbutt
ironbutt
Oops, I see it now...that hole is at the bottom center of the piece you just posted...at the risk of sounding dumber than a box of rocks...what is that in the pic?
2010 Camaro SS
9Back to top Go down   She sprung a leak Empty Re: She sprung a leak Tue Oct 29, 2013 4:29 pm
club_c
club_c
It's the Trans Michigan.  Laying on the face that mates with the engine.
10Back to top Go down   She sprung a leak Empty Re: She sprung a leak Tue Oct 29, 2013 4:48 pm
ironbutt
ironbutt
Well I guess I'll be taring into things come December... I'll be checking back then to find out all the things y'all think should be done at the same time I have all that opened...final drive etc. Thanks y'all for your brains... Cuz I left most of mine at Woodstock!
See ya down the road!
2010 Camaro SS
11Back to top Go down   She sprung a leak Empty Re: She sprung a leak Tue Oct 29, 2013 8:45 pm
ironbutt wrote:While we're on the subject of gear oil...if someone could share the dimensions of the transmission fluid gauge that would be most helpful!
Here it isShe sprung a leak Page_310
12Back to top Go down   She sprung a leak Empty Re: She sprung a leak Wed Oct 30, 2013 3:14 pm
ironbutt
ironbutt
Thanks much Rick!
2010 Camaro SS
13Back to top Go down   She sprung a leak Empty Re: She sprung a leak Wed Oct 30, 2013 3:24 pm
The first thing to do is determine if it's motor oil or gear oil.  Gear oil smells like sulfur(rotten eggs.)
Motor oil: Engine rear main seal or clutch nut O-ring.
Gear oil: Trans input seal or the seal at the back of the clutch pushrod.
14Back to top Go down   She sprung a leak Empty Re: She sprung a leak Thu Oct 31, 2013 11:08 am
ironbutt
ironbutt
You're so right...no mistaking gear oil...not anything I'd want to use as an after shave!
2010 Camaro SS
15Back to top Go down   She sprung a leak Empty She sprung a leak Thu Oct 31, 2013 6:48 pm
Can anyone tell me what the little hook at the end of that gizmo is used for? I made one with a flat end and no hook, feel left out now.
16Back to top Go down   She sprung a leak Empty Re: She sprung a leak Thu Oct 31, 2013 6:54 pm
MikeP
MikeP
It's the C-spanner for the rear spring strut adjustment.
1992 K1
17Back to top Go down   She sprung a leak Empty Re: She sprung a leak Thu Oct 31, 2013 10:35 pm
japuentes
japuentes
Hi there, I don't have the c spanner, so I made the oil marks on a allen wrench.
Best regards.
JAP
She sprung a leak 2854237993 1988 K100RS SE/ABS
18Back to top Go down   She sprung a leak Empty Re: She sprung a leak Thu Oct 31, 2013 11:01 pm
The thing to remember and be wary of is when you do make one just make sure the L shape at the top will prevent it from falling into the gearbox.  don't ask and I wont have to say I am not telling how I know that.
19Back to top Go down   She sprung a leak Empty Re: She sprung a leak Thu Oct 31, 2013 11:42 pm
RicK G wrote:The thing to remember and be wary of is when you do make one just make sure the L shape at the top will prevent it from falling into the gearbox.  don't ask and I wont have to say I am not telling how I know that.
"Experience teaches us things we didn't want to know."
20Back to top Go down   She sprung a leak Empty Re: She sprung a leak Thu Oct 31, 2013 11:57 pm
I have a friend who says that the only reason we learn from our mistakes is to recognize them next time we make them.
21Back to top Go down   She sprung a leak Empty Re: She sprung a leak Fri Nov 01, 2013 8:20 am
japuentes
japuentes
That's why there is a magnetic dipstick in the tool box
She sprung a leak 652573
