1 Problem with FI relay Sat Oct 26, 2013 2:58 pm
KC100
Problems getting bike up and running. Narrowed it down to ground from ecu to pin 85 on fi relay. Have continuity on the wire from pin 7 of ecu to pin 85 of the relay, but when I try to start it, it is getting voltage from somewhere. I can run a wire from ground to back of relay and it will start. Does anyone know where i might be losing this ground from the ecu or will i just have to replace the ecu? sorry did not mention what bike. It is 1985 K100rt.
