1 Starter problem, Relay, electronics or motor? Mon Jul 28, 2014 5:52 am
Suicidalbadger
After a 3 hour ride parked over night, pressed starter button and starter relay buzzed but starter didn't turn. Changed relay, starter would turn just by shorting relay terminals, worked great once and then 10 min ride and back to just a buzz from relay?
Bike has new battery so voltage should be good, but it did seem better with the lights off? so is there a connection issue on the switch side of the relay?
Any suggestions welcomed I'm a bit stumped apart from stripping starter motor for an intermittent short? which looks quite involved.
It's a K1100 ABS II from 1999
Badger
Badger
