floyd
floyd
Anyone have any idea weather or not a K1100 output shaft (which I assume of the 12 rivet design) would fit in a K100?
Please tell me yes, you will make me a happy little vegemite.
JR_K100RS
JR_K100RS
G'day Floyd , yes , when my original 6 rivet unit was threatening to detonate a 12 rivet K1100 was installed , all good
JR
floyd
floyd
JR_K100RS wrote:G'day Floyd , yes , when my original 6 rivet unit was threatening to detonate a 12 rivet K1100 was installed , all good
JR
HOOOOO-freaking-RAAAAH!
thats fantastic. thank you sir, you've made my day
floyd
floyd
What other major engine components are compatible?
Anyone know of any resources outlining the similarities and differences?
Are they basically the same, only with different bores and/or strokes?
If you are thinking of putting the 1100 in place of the 1000 it is not as straight forward as you may think.
The ECU and injection is a stumbling block. I know of one person who tried to do it and had problems in that area and put the 1000 back in.
To be quite honest I reckon that the 8 valve engines are a better engine for the job. I have a K1100 and I would have no hesitation going to a K100 again, as far as I am concerned the electric screen was the only big improvement and I do get better fuel economy.
floyd
floyd
RicK G wrote:If you are thinking of putting the 1100 in place of the 1000 it is not as straight forward as you may think.
Absolutly, 100% agree with you Rick G. Very Happy
Just thinking about which other 'upgrades' could I scavenge of a 'wrecked' K1100.
Thinking, complete front end, throttle bodies, injectors, output shaft....
Wondering what else is in the realm of possibility...
and the paralever rear end ....
garn
im a lost sod
but love my old 8 valve girl
JR_K100RS
JR_K100RS
plus the 4.5x18 rear wheel & centre stand if they are not bent
JR
floyd
floyd
Sweet as....
The k1100 I just picked up comes sans rear end.... Will need to source a rear wheel eventually...good to know I have a suitable centrestand for the upgrade
acftfliehr
acftfliehr
I put in a 1100 output shaft into my 85 about 5 years ago from a used K1100..
Only issue was that the output shaft bearing on my 85 had to be reused, as at some point on the K100 line, they changed out the bearing/cases with a different design..
I just removed the K1100 bearing and installed my old output bearing which looked in great shape..
Dave
floyd
floyd
acftfliehr wrote:I put in a 1100 output shaft into my 85 about 5 years ago from a used K1100..
Dave
Cheers Dave,
Good to know.
Would the alternator work and be a sensible upgrade? Anyone know?
If you need more power...........up to 09/92 the K11 alternator was 33A same as the one on the K100,
from 09/92 it was upgraded to 50A.
floyd
floyd
Thanks Inge. Looks like ill be keeping the alternator too Wink Will be handy to charge laptop, camera batteries, ipod on the road to no where.
