How many different things can be wrong at once.
After cleaning and lubing the T/B bits, and replacing them, resealing the upper and lower rubbers, new screw clamps I put it all back together, and no change, still idling high. Bummer.
Have a real good look Robert. One lower manifold rubber clamp was inhibiting No.4 injector from sealing correctly, pull off and re adjust. Still the idle screw sitting high and choke light stays on. Re adjust and move a top rubber clamp, light off. Get out book, re set the "choke" cable clearance on idle screw, throttle on, throttle bar not closing down. What the flaming hell. Check me old mate the TPS. Take it off, have a good look at the way if fits onto the butterfly opening bar, and viola, someone earlier than me has forced the TPS on without taking regard of the flat bit that positions it correctly, and it has been holding the idle screw open all this time.
There have been many suggestions for me to look at this earlier but I just readjusted the "click" each time without taking the whole mechanism off.
So together with fixing up all the air leaks and finding and fixing this problem, I've had a fair test run today in traffic and roadworks, idling at 950/975ish all day.
I'm off for a long run as soon as I can, but feel confident that it has settled down.
Thanks to everyone who had suggestions, it's a great forum, and I'm sure I'll be need more help again but this one looks like being over.
Regards to all
