MikeisonTV
MikeisonTV
Which of the following 3 wires would I want use to hook up and aftermarket tachometer on a k75? It is a speedo/tach combo so it will already be grounded.
Wiring in a aftermarket digital tachometer EC2A1A53-0A4E-4A9C-8FE2-290C65AED610
16 - speed signal from ign. coil ( black/blue ) gives rpm signal for tach.
22,23 are from speed sensor in the final drive but the signal is unusable for aftermarket speedos.  You'll need to use the supplied sensor that comes with your instrument.
21 is an OUTPUT, not an input to your instrument.
MikeisonTV
MikeisonTV
So 16 is my huckleberry....gracias I would have guessed 21. THANK YOU
