1 Aftermarket Tachometer problems on K1100RS? Tue Jul 05, 2016 3:40 am
bikernut
I am fitting an aftermarket Tachometer to my 95 K1100RS and the instructions the tach came with say to 'simply' hook the RPM signal wire up to it. The needle does not even move when I did that. Found a part solution online with an earlier model K100 using a capacitor 10nF 630v and a 100K ohm 0.5w resistor is used in series.
Tried to copy this for my bike and now the needle works but jumps and jerks around 4-5000rpm. The speedo is one of these
http://www.ebay.com/itm/12000RPM-LCD-Digital-Odometer-Speedometer-Tachometer-For-Motorcycle-Scooter-New-/171837204331
Any suggestions would be helpful thanks??
