1Back to top Go down   Slow-running clock.  Empty Slow-running clock. Thu Oct 10, 2013 2:16 pm
AJ.Valente
AJ.Valente
The clock on my bike runs about five (5) minutes slow every day.
Any ideas on how to fix this?  scratch
Thanks in advance.
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
2Back to top Go down   Slow-running clock.  Empty Re: Slow-running clock. Thu Oct 10, 2013 5:08 pm
Hi AJ,
My first thought was an intermittent connection somewhere, but I've just looked at a clock and there is an adjuster on the printed circuit board.
However I don't know what it adjusts..........does anybody know?
 Slow-running clock.  Sam_0710
Although, if the clock used to be accurate, I would still think it's more likely to be an intermittent contact.
3Back to top Go down   Slow-running clock.  Empty Re: Slow-running clock. Thu Oct 10, 2013 8:01 pm
thanks for the pic paul
that pot ...is actually a variable capacitor ...probably some where between 5- 20 pf
the capacitor loads down the crystal nearby ....by adjusting it ...it certainly would make a difference by  a few percentage points
those capacitors use an air gap type principal ....and I would think in certain conditions ...could absorb some grime ...changing its natural range and loading
hope that helps
4Back to top Go down   Slow-running clock.  Empty Re: Slow-running clock. Fri Oct 11, 2013 1:46 am
the.postman
A little bit less enthusiasm with the throttle should help
SLOW DOWN......
Basic relativity.. Time and space etc.
Einstein told us as a body approaches the speed of light etc. etc  Slow-running clock.  Bolt10
1984 srx 600
1986 cbr1000f/h
5Back to top Go down   Slow-running clock.  Empty Re: Slow-running clock. Fri Oct 11, 2013 3:20 am
lol ...
I don't believe in Einstein .... its all theoretical bs
 the "doctor " has far more cred .....giggles
6Back to top Go down   Slow-running clock.  Empty Re: Slow-running clock. Mon Oct 14, 2013 3:22 pm
Aj,
Contemplating your clock slow running problem (in my tent at the weekend), I'd be inclined to have a look at the connection between the printed circuit strip and the pins that feed volts to the clock, they're riveted connections that can become intermittent.
Also, you could remove the clock from the cluster and feed 12v directly to the input sockets to see if it looses time. That would isolate the fault to either the clock or the wiring.
Good luck,
7Back to top Go down   Slow-running clock.  Empty Re: Slow-running clock. Wed Oct 16, 2013 12:12 pm
AJ.Valente
AJ.Valente
OK, thanks all.
It's going to be a winter project (here in N.America), so I'll update this thread sometime in the next several  months.
