1Back to top Go down   power drain Empty power drain Thu Nov 19, 2009 2:00 pm
les10
les10
i have fitted a brand new battery on my k 100 rt. in the last two weeks i,ve developed an electric power drain on the battery. the battery is drained and three cells of electrolite have been lost.
my local garrage cannot find where the power is being taken from any suggestion.
2Back to top Go down   power drain Empty Re: power drain Thu Nov 19, 2009 2:41 pm
Have you checked the layered electriacl schematic?
I has a tab that link to the drawing of everything staying powered when the ignition is off.
Click here to see the diagrams.
power drain Frog15power drain Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   power drain Empty lost me Thu Nov 19, 2009 3:22 pm
les10
les10
thanks way above me cant do dot to dot never mind read circuits he he
4Back to top Go down   power drain Empty Re: power drain Fri Nov 20, 2009 3:03 am
Hi Les, well you are going to need to learn and now is the time! First when you have a fully charged battery what is the current drain in amps or milliamps that you have measured and if you have not measured it please do so and let us know how much it is.
Next as you are measuring the current draw pull out your fuses one by one and replace those that make no change until you see a change in the current draw, write down the fuse number that caused the change and leave that one out and then pull the remaining fuses on by one putting back those that make no further change. Let us know which fuses caused a change in current drain from what to what and on which fuses. Report what you found. Did this problem happen only when you fitted the new battery?
5Back to top Go down   power drain Empty Re: power drain Fri Nov 20, 2009 3:10 am
This thread is the active thread for this topic.
6Back to top Go down   power drain Empty Re: power drain Fri Nov 20, 2009 9:14 am
les10
les10
thanks need to get a amp metre. and no it happened on the old battery and the new one. what metre do i buy?. its drawn 3 cells dry do you think it could be over charge ? if i use a fully charged battery from my car and put the leads on to start it after 3 times it runs down my car battery so major draw somewhere.
7Back to top Go down   power drain Empty Re: power drain Fri Nov 20, 2009 3:08 pm
Hi Les,
If you connect it to your car battery is there a hefty spark as you connect it to the bike? (I am assuming you have taken the bike battery out of the bike and only are only using the car battery?)
If it is flattening a car battery with three starts you do indeed have a heavy drain but that should give you a big fat spark when you touch the lead onto the bike battery lead terminal before you push the start button. Is your car battery a good battery? Does it go flat with three starts in your car? When you say it has drawn three cells dry do you mean the electrolyte is way down on just those three cells or are they the worst but all of the cells have gone down in level as well.
To answer your question about a meter to buy if you are flattening a battery with three starts and you are drawing a big spark when you touch the battery terminals onto the bike then don't try to measure it with a meter, most home meters only go up to about 10 amps unless you have an old car ammeter around and some of them go up quite a bit higher.
I know it seems like questions questions but we will get to the bottom of it.
8Back to top Go down   power drain Empty Re: power drain Fri Nov 20, 2009 6:17 pm
les10
les10
car battery good. only the 3 cells dry of electrolyte these next to the neg terminal same on the old bike battery. battery stil in bike just using car battery with jump leads to start bike.
9Back to top Go down   power drain Empty Re: power drain Sat Nov 21, 2009 3:23 am
Is the bike battery still in circuit? If so you need to get it out and check why only 3 cells had the drying out. Did you ever see the cells all full or did you not unreasonably take it on faith the shop had topped all up properly?
10Back to top Go down   power drain Empty Re: power drain Sat Nov 21, 2009 8:31 pm
les10
les10
was present when electrolyte put in and its was the same on the old battery. booked into garrage on tues doing my head in.
11Back to top Go down   power drain Empty Re: power drain Sat Nov 21, 2009 11:06 pm
Sometimes it takes a while for the electrolyte to seep down inside the battery cases as some have small clearances.
What does not make sense is with a new battery to lose electrolyte from only three cells. If the bike was overcharging all cells would experience an approximately equal drop due to overcharging removing the water.
If there was a high discharge current again all cells in the battery would be affected roughly equally not just 3 of them. Tell us what happens on Tuesday.
12Back to top Go down   power drain Empty Re: power drain Mon Nov 23, 2009 2:33 am
les10
les10
hi even stranger is that its the same 3 cells next to the neg. on both batterys. will let you know what the garrage says if indeeed they know.
13Back to top Go down   power drain Empty Re: power drain Mon Nov 23, 2009 12:39 pm
japuentes
japuentes
Something by the battery tray is puncturing the batterys?
Best regards
JAP
14Back to top Go down   power drain Empty Re: power drain Sat Dec 12, 2009 8:31 pm
Hey Les10, any news about your battery yet?
15Back to top Go down   power drain Empty Re: power drain Mon Dec 14, 2009 2:42 pm
les10
les10
put new battery on last week no probs yet but early days cleaned evrything and
16Back to top Go down   power drain Empty Re: power drain Mon Dec 14, 2009 2:43 pm
les10
les10
doing weekly check on levels
17Back to top Go down   power drain Empty Re: power drain Mon Dec 14, 2009 2:48 pm
Hi Les,
Just a thought did you check electrolyte level was the same in all cells so as to have a baseline in future checks? I know my battery has a white case with a line on the side but I have never been able to see the level from the outside and I have tried all sorts of lights shone from all directions including down from the top through the open top up holes to no avail.
18Back to top Go down   power drain Empty Re: power drain Tue Dec 15, 2009 7:58 am
les10
les10
i take baterry of put on level ground and check level seems ok at mo. its a matter of how long it lasts
