1Back to top Go down   Motor only run with stater engaged Empty Motor only run with stater engaged Thu Nov 12, 2009 9:36 am
lefty108
My K100RS has done this 3 times now. Within about 2 minutes of start up from cold will just die and only rev whilst starter is engaged. Came good twice but third time had to leave bike overnight, started and ran fine next day. Any thoughts on this problem. Bike has done 166K kilometres. Regards Lefty108
I would first clean all electrical connections for the computer(EFI/Electronic ignition) + ground. If this doesn't solve the problem, I would test the water temperature sensor .
It could be and internal electronic component shutting off when it warms up.
You may also have a small crack on a printed board or what is called a cold soldering.
Motor only run with stater engaged Frog15Motor only run with stater engaged Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
ReneZ
ReneZ
When is the last time you renewed the fuel filter? The fact that it does run when you press the starter makes me think it doesn't get enough fuel. When you press the starter the ECU gives extra fuel. If you run it with the tank cover open, do you see it spray?
Rene
BMW K100 - 1985 (0030029) Scotland Motor only run with stater engaged Rain
lefty108
Crazy Frog wrote:I would first clean all electrical connections for the computer(EFI/Electronic ignition) + ground. If this doesn't solve the problem, I would test the water temperature sensor .
Thanks for reply, will try suggestions.
Regards
lefty108
Perth, Australia
lefty108
ReneZ wrote:When is the last time you renewed the fuel filter? The fact that it does run when you press the starter makes me think it doesn't get enough fuel. When you press the starter the ECU gives extra fuel. If you run it with the tank cover open, do you see it spray?
Fuel filter is less than 10000 ks old, have not checked with the tank open.
Regards
lefty108
Perth, Australia
