1Back to top Go down   battery drain Empty battery drain Thu Nov 19, 2009 5:11 am
les10
les10
i have a k100 rt which as been fitted with new heavy duty battery. the battery as been totally drained. 3 cells totally dry.
whats can be causing the problem and how do i go about finding the leak
2Back to top Go down   battery drain Empty Re: battery drain Thu Nov 19, 2009 8:48 am
A stupid question that has to be asked...was there acid in all 6 cells before it was installed on your bike?
There should be a very obvious leak under your bike...check for peeling paint/stained aluminium parts etc.
Over what length of time was it from installation of battery to finding out about the 3 dry cells?
3Back to top Go down   battery drain Empty Re: battery drain Thu Nov 19, 2009 1:56 pm
les10
les10
sorry i did,nt explain it well theres a electical drain on the battery. not a physical leak of electrolite. all cells were topped up when new. but the bike is draining the power out of the battery
4Back to top Go down   battery drain Empty Re: battery drain Fri Nov 20, 2009 3:09 am
This topic is locked see other thread Power Drain.
K-Bike
