51 Re: Tasmania 2014 Sat Oct 19, 2013 4:43 am
ausbrick
Go to page : 1, 2, 3, 4
some fairly serious works on the run there Al, hoping to avoid the major issues if possible, and enjoy the trip.AL-58 wrote:K Things we've had fail or break while travelling(that have needed repair or babying to get us home):
K75s final drive and driveshaft spline failure
K75s stripped clutch spline/input shaft
K100RT sidecar clutch cable
K100RS-16v sidecar clutch cable
K100 frame (snapped right downtube)
K75s frame (snapped rear loop behind the top shock mount) -overloaded and rough roads
Lower shock mounting stud on rear drive
K100 starter motor brushes.
K75s ding in the front wheel from rough roads (tyre wouldnt seat, wouldnt hold air)
I really should carry a clutch cable.
Last edited by groverK on Sat Jun 21, 2014 12:04 am; edited 2 times in total (Reason for editing : forgot the esky)
floyd wrote:Wow thats a scary list of on road failures Al....
Broken from, stripped clutch splines, busted FD.....far out.
Will be sure to add a set of starter bushes to my next shopping list.....
My recently fitted front tyre (on K1100 rim) has deflated after about 2 weeks of sitting idle.....bugger. Ideas? Maybe just running a tube in it....
groverK wrote:so does this mean no to using tubes as a short term repair?
Of course it doesnt. Ive run tubes in tubeless tyres for years without any problems. Its probably not ideal, but it will get you home no worries.
thats right Waz , I'm sure most would agree with you. 1 week is tight ,Waz wrote:
How long would you go for?
Good question, I went in the car for a week and it was not long enough.
Last edited by Kyle10 on Wed Jun 25, 2014 7:24 pm; edited 1 time in total (Reason for editing : snark)
Ghost who rides wrote:
"...sadly modern technology makes it ridiculously easy and sooo profitable..."
Similar topics
