1 K75 electrical weirdness Sun Jul 21, 2013 5:44 am
jjefferies
Hello, last week installed a LED bulb replacement kit in my K75 instrument pod. Installation wasn't a problem but on my second ride and the first after dark I found that the bulb monitoring warning light (rear brake light) in the pod would occasionally flash when I tapped either brake. To make it more interesting the Alternator warning light would also occasionally flash at the same time and infrequently the oil warning light might join in the fun. I checked the brake and rear running light and both are working fine. I also checked the fuses to insure that they are inserted properly.
While at this time I don't suspect the LED's other than they are probably more sensitive than the original incandescent bulbs I'm wondering if there's a common failure point where all three warning lights might be affected.
Has anyone else seen or recollect hearing of such weirdness? The problem was not apparent before I installed the LED's which leads me to think it's something I disturbed in the pod as opposed to the BMU going bad. The occasional flash of the alternator and oil lights would seem to suggest that. Looking at the circuitry diagrams it appears that all three feed to the same ground but not sure how that would cause the flashing.
thanks
JJefferies
thanks
JJefferies
