1 odometer gears Fri Jul 19, 2013 6:05 am
sak3
A few days ago I noticed that the speedometer on my bike worked fine, but the odometer had stopped working.
Remove the box and found that the gear box had waste.
Are five gear transmission comprising odometers (full and partial)
Here are four of the five missing tractor gear because I have not disintegrated.
Usually spoil the first two more tractor gear (as you can see in the photos).
The problem in making a new printing is but in the setting, for it had to perform several tests, and know the type of material to use to play the gears and the potential life of these.
I have the good fortune to live in an area where many toys are made and where the use of plastic, abs and resins is quite common.
I am in touch with my good friend George and I made the design and subsequent adjustment
getting this
adro had waste.
We value the experience of different people and we decided to print a 3D printer in ABS, getting this set.
and is now assembled.
And we test its performance
[video=youtube;qo10wTMQxhk]https://www.youtube.com/watch?v=qo10wTMQxhk[/video]
This is the normal operation of the box but to try a little slow.
NOTE: The mileage is 907.463
and this is different tests.
The sound you hear is the engine that I use to move the emgranajes
NOTE: The mileage has increased by 40,000 km with what at that speed I think you can say that will last much longer than the others.
The test time was one hour
Regards
getting this
adro had waste.
Regards
