1Back to top Go down   Odometer gears Empty Odometer gears Tue Apr 19, 2016 11:58 pm
Rockman
2Back to top Go down   Odometer gears Empty Re: Odometer gears Wed Apr 20, 2016 12:26 am
Basic2
Basic2
Hi Rockman is that for an individual gear or the whole train of gears?
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
3Back to top Go down   Odometer gears Empty Re: Odometer gears Wed Apr 20, 2016 12:57 am
Rockman
Basic2 wrote:Hi Rockman is that for an individual gear or the whole train of gears?
I dunno. Looks like a big one and a little one. I'm trying to find out any info on them.
4Back to top Go down   Odometer gears Empty Re: Odometer gears Thu Apr 28, 2016 5:21 am
floyd
floyd
I got a set for my early K100 from this bloke. He is based in the South of Sydney and sells a range of odo gears. They were $25 ea and i needed all 4 I think....
richardws (at) aapt dot net dot au
He refers you to this page for info, but I highly recommend you dismantle the unit to see what you need... ODO GEARS
5Back to top Go down   Odometer gears Empty Re: Odometer gears Thu Apr 28, 2016 5:34 am
Basic2
Basic2
floyd wrote:I got a set for my early K100 from this bloke. He is based in the South of Sydney and sells a range of odo gears. They were $25 ea and i needed all 4 I think....
 That's who I used - good service. I got him to repair the odometer.
http://www.repairsonly.com.au/index.html
K100 Basic 2
Marakesh Red
6Back to top Go down   Odometer gears Empty Re: Odometer gears Thu Apr 28, 2016 5:42 am
The small "driver" gear you can get in a pack of gears from Jaycar for about $8 whereas you will be charged $25 for it plus delivery. The other gears you will have to get from him.
7Back to top Go down   Odometer gears Empty Re: Odometer gears Thu Apr 28, 2016 7:13 pm
Rockman
I looked at getting a set of gears from the US via Floyds link, but I balked at the cost of $150+ to Aus and decided I didnt really need to know the odo reading THAT much. Maybe the bloke in Sydney is the go.
8Back to top Go down   Odometer gears Empty Re: Odometer gears Thu Apr 28, 2016 7:21 pm
floyd
floyd
Rockman: The bloke in Sydney is the Aus distributor for that USA website. His contact details are listed in the 'distributors' section I think.
$25 per gear plus $10 courier.
9Back to top Go down   Odometer gears Empty Re: Odometer gears Fri Apr 29, 2016 1:53 am
Rockman
Yes, he must get them cheaper than I could direct. Postage was USD35 which I thought was too much for some little tiny plastic gears.
10Back to top Go down   Odometer gears Empty Re: Odometer gears Fri Apr 29, 2016 2:24 am
yeah its a pity that usa charge a premium for putting absolutely anything in the post to anywhere outside  of us ...are they scared or something ? or just cant be bothered to have a pickup service that does a service ...like bringing the correct declaration form ...sheesh, bet you is a downloadable declaration at that, from what I have seen ...or is it just the bother of putting pen on paper and being required to think ...!
crikey we send over a hundred k of our stuff international ....every couple of months ... and don't have the same issues , and more paperwork is required indeed ...but no where near the same postal charges rate . shoot id start a new business if I could get what they are asking . us $35 for a $5 post bag ???
11Back to top Go down   Odometer gears Empty Re: Odometer gears Sun May 01, 2016 7:51 pm
Rockman
I dismantled my instruments on the weekend. All the gears on the odo are shot. They literally crumble when I touch them. I think I'll contact the bloke in Sydney and find out a cost if I send the speedo to him to fit new gears.
EDIT: Emailed Richard. $100 for 2 gears + $25 for each extra. I'm going to post it down to him for repair. Save a lot of stuffing around.
Last edited by Rockman on Mon May 02, 2016 12:31 am; edited 1 time in total (Reason for editing : update)
12Back to top Go down   Odometer gears Empty Re: Odometer gears Mon May 23, 2016 10:23 pm
HighlyBlessed
HighlyBlessed
ainsjac wrote:The small "driver" gear you can get in a pack of gears from Jaycar for about $8 whereas you will be charged $25 for it plus delivery. The other gears you will have to get from him.
Can you provide some clarity? I also need to replace a small gear in the cluster (based on previous owners advice. I have not looked yet) and you mentioned this: http://www.jaycar.us/search?text=Gear  Is the heat set shown the one to order??
J.K. 85 k100rt
13Back to top Go down   Odometer gears Empty Re: Odometer gears Mon May 23, 2016 11:17 pm
OK...if you type in "gear set and spur gear set" you will get a photo of the set. The smallest single gear will replace the similar one in your instruments  and cheaper. The rest of the gears cannot be used as replacements.
Good luck.
14Back to top Go down   Odometer gears Empty Re: Odometer gears Mon May 23, 2016 11:33 pm
HighlyBlessed
HighlyBlessed
ainsjac wrote:OK...if you type in "gear set and spur gear set" you will get a photo of the set. The smallest single gear will replace the similar one in your instruments  and cheaper. The rest of the gears cannot be used as replacements.
Good luck.
Got it! If it is only the smallest one I need, it'll only cost me a few bucks.
Thanks!
J.K. 85 k100rt
