1 2002 K1200RS Brakes Thu Aug 08, 2013 11:08 pm
martensx
My K1200RS when ignition is turned on goes through its ABS checking routine but the ABS warning light does not slow down to the slower rate. When the front brake is applied the ABS brakes operate and the motor function is audible. When the rear brakes are applied this is not the case.
I had a BMW trained person hook the bike up to his computer and it came up with an error code 17419 but he said that he doubted that this was right as he had never seen this rear motor for the ABS fail before. I contacted a major BMW parts supplier in Australia and similarly they told me to look elsewhere for the fault as they had not seen this motor fail.
I am at a loss as to what to look at next. The alternate BMW dealer is some 180k away and I don't really like riding when the brakes are not working properly.
With this model if the power assist to the brakes fails it is almost the same as having no brakes.
Any suggestions on how I might cure this issue?
