1Back to top Go down   Best way to clean painted wheels? Empty Best way to clean painted wheels? Sun 04 Aug 2013, 16:35
BlueWater
BlueWater
So I have this new to me K100 Wulf Gerstenmaier special which I did quite a bit of cleaning on when I got it but the wheels still need quite a bit of attention. Looks like they are painted silver and the paint seems to be in good nick but there is quite a bit of road grime/brake dust built up.   Used the search feature and it seems like just dish soap and a toothbrush seems to be the preferred method?  Anything else to try?  Thanks for the attention.
Best way to clean painted wheels? IMG_0999
Best way to clean painted wheels? IMG_1007
Best way to clean painted wheels? IMG_1006
The simple answer is "with a great deal of patience".
I have said many times that the mug that designed those Y spoke wheels should be made to clean them for evermore as a punishment.
3Back to top Go down   Best way to clean painted wheels? Empty I think Sun 04 Aug 2013, 17:00
ibjman
ibjman
I think you may find that after you get these off & close inspection, that you may have some actual corrosion coming up from the aluminum surfaces under the paint, possibly because the area was not properly prepped before.
 My machine was badly corroded from years of exposure in storage in salty ocean air.....
My solution was to get a big round water heater spill tray & plug the drain hole.....using that for a scrub pan.....a couple of small 2X4 pieces around the edge to support the wheel rim on center. I wasn't worried about the tyres, cause I planned on replacing them anyway.
I used a combination of chemicals, including phosphoric acid and or industrial strength commercial  "Purple Cleaner" along with a couple dozen "wire toothbrushes" from the home improvement center and a couple of boxes of latex gloves. Followed by doses of clear water from a spray bottle for rinsing.
After scrubbing all the old finish + all the black corrosion out of all the tiny pits & corners, I refinished the wheels with "dupli-color" wheel paint + 2 layers of clear from the local auto parts store.
If I were doing it again, I would probably powder coat them next time.
As I remember, it took me about a week for each wheel. As I said, mine were really nasty.
Before:
Best way to clean painted wheels? Front_10
After:
Best way to clean painted wheels? Photo010
Regards, Ibj...
the.postman
Looks like another job for "The Dishwasher"  Twisted Evil
Next time the wheels are stripped right down
1984 srx 600
1986 cbr1000f/h
BlueWater
BlueWater
The unfortunate thing is I just replaced the tires. I know I should have taken the time then to deal with this then but I was itching to ride her.
JR_K100RS
JR_K100RS
Big effort ibjman ! , snaps to you
JR
Melbourne Australia
JR_K100RS
JR_K100RS
I reckon your thing would look better with 3 spokers Bluewater , it would really suit the bike , perhaps the 4.5 inch rear upgrade ?
JR
Melbourne Australia
8Back to top Go down   Best way to clean painted wheels? Empty ooops, forgot Mon 05 Aug 2013, 07:20
ibjman
ibjman
Forgot to mention that along side the commercial purple cleaner, and the phosphoric acids, I also had a gallon jug of Simple Green that was mixed with water in various combinations.
I think a soda or glass bead blaster would have been a better alternative.
Regards, Ibjman
BlueWater
BlueWater
So got after one side of rear wheel this morning. Dish soap/water with toothbrush followed by 0000 steel wool.  Not bad took about an hour.  Not perfect but at least a start.  Man those corners are a B****!
Rear I cleaned
Best way to clean painted wheels? IMG_1027
Front I didn't
Best way to clean painted wheels? IMG_1028
