1Back to top Go down   1985 K100RT Rebuild Empty 1985 K100RT Rebuild Tue Dec 11, 2012 6:41 pm
dmanley
dmanley
This is my first BMW motorcycle and I started out planning on changing the fluids and control cables. I'd then ride the bike a few months and get a better idea of what it really needed. After starting the work it quickly escalated into what the heck I'll just dive in to it.
I'll post links to photobucket to show the progress. This is also a first so I'm sure there'll be a few mistakes. I'm also sure someone from this friendly audience will let me know! The current link showing the start of the teardown is below. Let me know what you think.
My current question:
1. I wasn't planning on opening the engine. The odometer has 40k on it and it seemed to run well the 50 miles I drove it. I am replacing external seals. While I have it torn down is there anythin in the engine I should address?
Here she is:
http://s1327.beta.photobucket.com/user/d_manley/story/22849
Daryl
1985 K100RT
2Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Dec 11, 2012 6:50 pm
Replacing the external seals is a good idea as they do age. I would be inclined to replace the camchain guides as age seems to affect them as much as miles does. They may look OK but will probably wear quickly once you start using it.
The other thing is to check the valve clearances while you have the time to order shims and wait for them to come.
3Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Dec 11, 2012 10:06 pm
Could be a good idea to check the rivets on the absorber at the intermediate
shaft also.
To check, remove all screws at the RHS cover and swing the cover out at the
rear end.
Put the bike on the centerstand and put it in gear, move the rear wheel forth and
back while keeping a close look at the rivet(s).
1985 K100RT Rebuild Demper12
4Back to top Go down   1985 K100RT Rebuild Empty Continue Work Mon Feb 11, 2013 3:50 pm
dmanley
dmanley
Still working on the bike. Changes include:
- New coolant hoses and fuel lines
- New cables (clutch, throttle and choke)
- Replace all rubber, to include tires
- New brakes and rotors
- Powder Coated most part gloss black or aluminum
- Built Hall tester and set Hall Transmitter
- Installed progressive springs
- New clutch and associated parts
- All body parts out to paint
Starting the assembly without the frame on to make it easier. Things going well so far:) here she is:
http://s1327.beta.photobucket.com/user/d_manley/library/
Daryl
1985 K100RT
5Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Mon Feb 11, 2013 4:32 pm
looking really nice there ,,,,great work
6Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Mon Feb 11, 2013 5:15 pm
dmanley
dmanley
Now if it only runs when I get done:)
Daryl
1985 K100RT
7Back to top Go down   1985 K100RT Rebuild Empty 1985 K100RT Rebuild Mon Feb 11, 2013 5:25 pm
Wow Daryl, nice work mate. Look forward to seeing it back together. Well done
8Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Mon Feb 11, 2013 7:36 pm
Brickee
Brickee
Wow, you did more in 2 months than I did in 2 winters worth of work. Nice work and that powder coating looks sharp.
From the piccs you took taking it apart and the labeling, it should start up w/o a problem, but if you do, it'll make it easier to diagnose. Happy wrenching. cheers
Brickee
86 K100RT VIN 0053533
The good news is, I no longer have senior moments. The bad news is, now it's a constant state of mind.
9Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 12, 2013 10:32 am
Brickee wrote:Wow, you did more in 2 months than I did in 2 winters worth of work. Nice work and that powder coating looks sharp.
Brickee
+1
inspiring work. Well done.
1985 K100RT Rebuild Ir-log1188....May contain nuts!1985 K100RT Rebuild Ir-log11
K75RTP - 1994
10Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 12, 2013 10:36 am
dmanley
dmanley
Thanks guys.
Daryl
1985 K100RT
11Back to top Go down   1985 K100RT Rebuild Empty Painted Parts Tue Feb 26, 2013 11:47 am
dmanley
dmanley
Assembly continues to go well and I received the painted parts last week. I was most worried about the wiring harness install but that actually went well. My only snag was not pulling the radiator fan connector down from the harness to the radiator. Required a little digging.
Here are the latest pictures:
http://s1327.beta.photobucket.com/user/d_manley/story/55075
Daryl
1985 K100RT
12Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 11:55 am
club_c
club_c
That looks so good! Remember to use BLACK zap straps (the white ones decrease fuel economy).
1988 K100RS SE VIN 01477554
13Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 12:20 pm
dmanley
dmanley
Funny you noticed the zip ties. I used white ones until I had a chnace to get to the store. ALL Black now:)
Daryl
1985 K100RT
14Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 1:18 pm
You now have made yourself deserve a lifetime membership in Blakey's zip tie club.
15Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 2:22 pm
MikeP
MikeP
Very nice indeed. 1985 K100RT Rebuild 112350
16Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 3:41 pm
dmanley wrote:Funny you noticed the zip ties. I used white ones until I had a chnace to get to the store. ALL Black now:)
Must be white on the speedo connectors though..........or the rivet counters will be after you! 1985 K100RT Rebuild 167893
17Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 6:43 pm
frogy
frogy
Don't be surprised if someone asks you if thats a 2013 model BMW because "We have not seen it advertised yet.1985 K100RT Rebuild 112350
Very clean work.
18Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 6:45 pm
frogy
frogy
What front rotors did you use?I like the look of the floating rotors
19Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 7:41 pm
Very nice indeed I really like the colour and depth to the paint work.
A general question for all to answer, is that filler hole in the tank back futher than usual or am I seeing things. It looks to me that it is back where the tanks that have the small compartment is. Maybe it is an early tank thing I have just never noticed.
20Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 8:43 pm
I had to take a look at my own to compare...but yes certainly on a 1984 the hole is in the same place...it now looks strange on mine now..
KKlompy 1985 K100RT Rebuild 2854237993
1985 K100RT Rebuild Au-log10
21Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 8:52 pm
I have been looking at the K75 and K1100 and I am not sure but I reckon its about 15mm futher back, either that or the slope at the back starts a bir closer to the cap.
22Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 9:16 pm
1985 K100RT Rebuild Sany0214
1985 K100RT Rebuild Sany0215
1985 K100RT Rebuild IMG_0694_zps7b57689e
23Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 9:29 pm
I think it may be an illusion because of the reflections in the paintwork that I am not seeing where the downward curve starts.
Now that I look back at the tank pictured earlier it is very pronounced where the filler is.
Probably Grandad eyes. 1985 K100RT Rebuild 610153
24Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Feb 26, 2013 9:39 pm
Rick G wrote:Probably Grandad eyes. 1985 K100RT Rebuild 610153
I had to take a double take too....it just goes to show how excellent that paint job is....I was going to do my own but I am certain my results would not be that good...
25Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Feb 27, 2013 3:48 am
AJ.Valente
AJ.Valente
Nice bike D, I really like the paint job and detail work.
It looks to have an LT front windshield, also rear clip and top box of the LT variety. According to RealOEM.com the early bikes are listed only as RS or RT, seems there was no formal LT designation until '87.
26Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Feb 27, 2013 10:27 am
dmanley
dmanley
Both the front and rear rotors are EBC. They were reasonably priced and look great on the bike.
The paint job is from a local shop here in Alabama. The color is for a Ford (FX Merlot Red Series 295). Once I reassemble the bike the paint shop will wet sand it and do the final buff. From what it looks like already it should be great.
I only rode the bike a few times before I tore it down. The only thing I wasn't sure about was that my knees push in to the the pads that fill in between the fairing and the bike. I'm only 6 foot tall so it seemed odd.
Daryl
1985 K100RT
27Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Feb 27, 2013 4:16 pm
long legs short body?...I have heard of a few complain about getting caught up in the fairing under heavy braking...but I believe that was LT's only.
28Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Feb 27, 2013 4:29 pm
dmanley
dmanley
Actually short legs and long body:) This appears to have the same fairing as the later LT so maybe it's just the way it is, I'll see once I get it complete. Worse case I'll do a bit of a mod...
Daryl
1985 K100RT
29Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Feb 27, 2013 5:28 pm
dmanley wrote:Worse case I'll do a bit of a mod...
Worst case......it must on the legs then?
30Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Feb 27, 2013 5:40 pm
dmanley
dmanley
No...I'll see if I can modify the filler panels to allow more leg room.
Daryl
1985 K100RT
31Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Feb 27, 2013 5:45 pm
MikeP
MikeP
dmanley wrote:The only thing I wasn't sure about was that my knees push in to the the pads that fill in between the fairing and the bike. I'm only 6 foot tall so it seemed odd.
BMW shifted the whole thing forward a few inches with the 1100. With the standard seat it wasn't an issue but the LT (and many after-market) seats push the rider forward a bit.
1992 K1
32Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Feb 27, 2013 5:49 pm
dmanley
dmanley
That explanation helps a lot since it has a Corbin seat. I was going to replace the seat, probably with another Corbin, but I'll ask about the position first.
Daryl
1985 K100RT
33Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Feb 27, 2013 5:56 pm
frogy
frogy
Had the same knee problem on mine before tearing it down. 6'2" and every time I stopped I wacked my knees.I do not and will not miss the fairing on this bike. Plus some of the fairing bits have been sold for this project-no going back now.
34Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Mon Mar 11, 2013 7:24 pm
dmanley
dmanley
After a few months torn apart she started pretty easily. First time I tried no luck, but after I corrected two switched wires on the coil she cranked. I went right to the coil wires because the Clymers manaual was a bit confusing so I had made a mental note to start there if I had issues.
I added a few pictures at the end of this slide deck that shows the bike with the tank and instrument panel installed for starting.
As it ran I noticed if you bumped the instrument panel it would drop out. I made a fitted washed that presses against the two instrument cluster connectors, and fits under the cover, and that was solved.
Only current issue is deciding which legth rear wheel bolts to use. The BMW microfiche shows them as 60mm. The Clymers says 60 mm with drum brakes and 55 mm with disc brakes. Haynes says 60mm with disc brakes and 55 with drum brakes. Which is right?
Daryl
1985 K100RT
35Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Mon Mar 11, 2013 7:29 pm
MikeP
MikeP
Haynes. The parts fiche shows 60mm for disc brake wheels.
Looking very nice.
36Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Fri Jun 14, 2013 6:22 pm
dmanley
dmanley
I'm not completely done but I do have the bike back on the street. I only rode it twice before I started the teardown and I'm amazed at how great it rides. Get her up to 75 mph and she's good all day. Current pictures are at:
https://s1327.photobucket.com/user/d_manley/library/1985%20K100RT%20Assembled
Things still left to do include:
- I have a Corbin Canyon Dual Sport seat on order
- I have a Clearview windshield on order
- My fuel level lights are acting up so I need to pull the fuel level sender to see what's up.
Other than that I'd say she's ready to go.
Daryl
1985 K100RT
37Back to top Go down   1985 K100RT Rebuild Empty Keep in mind Fri Jun 14, 2013 7:24 pm
ibjman
ibjman
Remember that the fuel control lights on the 85 never worked very handily. BMW offered up a service bulletin to remove the 7L yellow lamp and add a 90 sec. delay to the function of the 4L red lamp.
When working as designed, The yellow lamp may start flashing or flickering on & off  about 55 - 75 miles from fill up. Depending on how the fuel is sloshing around, the temperatures, etc.....it'll be on more steadily after100 miles. The red 4L light should be coming on around 135 - 140 miles again it will come on & go off with the movement of the fuel around the sensor.......I usually re fuel at 175. I would expect to run out at about 220.
If your fuel lights are working similarly to the description, they don't need fixing.
I do have an upgraded 85 instrument cluster available that has new odometer gears as well and calibration checked + a new rubber housing gasket.
Unfortunately, I'm invested in it pretty deep so I need quite a bit of money for it.
Regards, Ibj...
38Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Jun 18, 2013 6:48 pm
dmanley
dmanley
ibjman wrote:Remember that the fuel control lights on the 85 never worked very handily. BMW offered up a service bulletin to remove the 7L yellow lamp and add a 90 sec. delay to the function of the 4L red lamp.
Regards, Ibj...
IBJ - The lights actually worked correctly before I started the rebuild. Now the yellow never comes on and the red goes on and off as it pleases. I'm guessing the sending unit didn't like sitting in a bag on the shelf for the few months when it was out of the tank. No issue, I'll rely on the trip counter for now. Thanks.
Here is an updates link to the pictures in the previous post. It was having issues when I posted it the first time.
Daryl
1985 K100RT
39Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Tue Jun 18, 2013 10:55 pm
I always use my trip meter, I just have a inbuilt distrust of a gauge of any sorts.
40Back to top Go down   1985 K100RT Rebuild Empty During the rebuild Tue Jun 18, 2013 11:32 pm
ibjman
ibjman
During the rebuild, what if any work was done to the speedo itself? Also.....could be that one of the 4 wires in the connection between the tank & the wiring harness connector is not quite connecting well. The board in the speedo.....sends voltage down the 2 wires to the sensor to heat the various thermistors......their temps vary the resistance affecting the voltage.
Depending on the voltage measured at each individual "op-amp" they either switch the corresponding transistor on or off to illuminate the lamp.
I had my sensor out on the bench for many months......it caused no problems. In addition, I sold a similar sensor that had been out on the bench for the same time to someone else here on the forum. As far as I know, it worked Ok too.
I suspect the problem with the second fuel light could be a poor connection inside the instrument cluster rather than a defect in the sensor.
41Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Jun 19, 2013 8:57 am
AJ.Valente
AJ.Valente
My '85 had the recommended service on fuel lights and the "71" bulb removed. But, when I upgraded to LED's in the cluster I put an amber element back in, so everything works as intended once again.
Like most riders I go by odometer, but just wanted to see what the fuss was all about. When they raced this model the yellow light would be the signal to refuel.
The red light works like the reserve. With the old petcock one had to do this manually, and so I like this design better. No longer do I worry whether I've turned the fuel on or have forgotten about running on reserve (dope!).
My intention while touring is to take a break when the yellow light comes on and refuel. Some people may prefer the Iron Butt style of touring, but thankfully I'm of the age now where I enjoy the little things a bit more. Smile
42Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Jun 19, 2013 10:19 am
dmanley
dmanley
Hadn't thought about checking the bulb again for the yellow light but I'll do that.
Daryl
1985 K100RT
43Back to top Go down   1985 K100RT Rebuild Empty my recollection Wed Jun 19, 2013 11:30 am
ibjman
ibjman
My recollection was that the bulletin...(recommendation) was not only to remove the yellow bulb, but to also upgrade the fuel lamp control board in the cluster to the newer board with only 1 lamp circuit and a 90 second delay feature to prevent the annoying intermittent flashes as the fuel neared the trigger level.
Their could have been more than one recommendation published however.
Regards, Ibj...
Pat O'D
Pat O'D
great work every part nice and shiny bike will look just great
Pat
1991 K100LT Red (VIN 0191558) 138000 Miles
1985 K100RT Rebuild Ir-log10
45Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Thu Jun 20, 2013 11:14 am
dmanley
dmanley
Thanks Pat. I'll update once I get the new seat and shield.
Daryl
1985 K100RT
46Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Aug 14, 2013 7:35 am
slazzman
slazzman
That Daryl my freind is thing of beauty and a credit to you. This is inspiring me to do mine over the winter, Cheers John
1985 K100RT Rebuild 24109250201984 K100RT
47Back to top Go down   1985 K100RT Rebuild Empty Re: 1985 K100RT Rebuild Wed Aug 14, 2013 9:49 am
nice job !!!
