I had to replace my K75s top triple clamp due to a broken bolt where it clamps the fork leg.
I sourced a replacement one online.  It was a bit grotty when it arrived so I thought I'd give it a clean before fitting it.
The result:
This forum is having a bad effect on me. Tripleclamp_zps4ccc1acc
To achieve this I separated all the bolts, washers, clamps and soaked everything in a bucket of Chemtech Blitz aluminium cleaner (200ml:3 litres water) for about 24 hours.  Then gave them a final wash in hot soapy water with a brush to get into the tricky bits.
Before I would have just bolted it on and said bugger it.  Now the triple clamp puts the rest of the bike to shame.
I'll be using this witches brew from now on.
Last edited by AL-58 on Sun Aug 18, 2013 7:47 am; edited 1 time in total (Reason for editing : clarifcation)
'93 K1100LT
This forum is having a bad effect on me. K-dogs10
Al, join the rest of fools on this forum. We will be checking to see if your tyre valves are clean enough soon.
looks good.Smile   job well done Al, you make it sound so easy.
This forum is having a bad effect on me. 10_x_110
quietly smiling to myself.
groverK wrote:looks good.Smile   job well done Al, you make it sound so easy.
That's because it was that easy!
'93 K1100LT
good tip al ...thanks
will get some real soon
the.postman
Looks like you've do a grand job.
We don't seem to have that witches cocktail in old Blighty, and was wondering if you could give us a hint of the main ingredients so I could see if there is a similar brew to be had here.
This forum is having a bad effect on me. Evil-w10
1984 srx 600
1986 cbr1000f/h
the.postman wrote:Looks like you've do a grand job.
Here's a link to the material safety data sheet from the manufacturer:
[url=http://www.chemtech.net.au/Blitz MSDS.pdf]http://www.chemtech.net.au/Blitz%20MSDS.pdf[/url]
'93 K1100LT
the.postman
Thanks. It's PHOSPHORIC ACID based.I'm sure I can find a similar "BREW" here
1984 srx 600
1986 cbr1000f/h
Watch that stuff Shocked...it can set off a chain reaction, pretty soon it will have spread to the gearbox casing, then the final drive will start to shine.
This forum is having a bad effect on me. Carefu10
This forum is having a bad effect on me. Ir-log1188....May contain nuts!This forum is having a bad effect on me. Ir-log11
K75RTP - 1994
the.postman
Yes. I know what you mean !!!!
I removed the clutch to find the cause of a rattle.... (I think I've sorted that.. Thrust washer was knackered)
I'm now polishing the heads of bolts, painting battery trays, polishing exhaust headers, powder coating wheels etc. etc. etc.
1984 srx 600
1986 cbr1000f/h
Do you think this stuff would damage a throttle body? I got some here.
I'm pretty sure my R1100 TB repair kit is at the post office, I got a pickup card today. The TB itself is filthy.
13Back to top Go down   This forum is having a bad effect on me. Empty metal cleaner Tue Aug 20, 2013 3:50 pm
Gordon Smith
Gordon Smith
Hi Postman, tried some stuff called Bar Keepers Friend--- IT WORKS. Cleaned last winters muck off forks and casings with no real effort. Its based on Oxalic acid and Citric acid. Web site is www.
kilrock.co.uk   I got mine from my local hardware stores £2.50. Don't use it on mirror finish, but it works well on the stippled casings and used well let down on stainless brake rotors:D
xpc316e
xpc316e
Thanks for the Barkeeper's Friend tip - I shall give that a try.
RobinW wrote:Do you think this stuff would damage a throttle body? I got some here.
Whene I soaked the triple clamp, the shiny machined surfaces were still shiny machined surfaces, it did not eat into it it or degrade it in any way just removed the ingrained discolouring on the cast surfaces.  I dont think there would be a problem.
'93 K1100LT
I have been using Blitz for a long time and I have found that you need to give it a really good scrub to clean the final application or it gets the white alloy bloom on it very easily.
I got put onto it by a customer that used it to clean the alloy bull bar and mudguards on his truck.
To clean a throttle body I use the carbie and injector cleaner, I don't know what is in it but it gets rid of the varnish build ups in no time flat.
Rendrag
Rendrag
Chemtech Blitz eh Al? Where does one buy it? Smile  Might clean up all the parts off the K100 before I list them up!  (And clean up the levers and triple clamps on the viffer!)
2000 VFR800
I just used it on the outside. Put it on with a toothbush. Took 3 goes and left it on for 10minutes each time but it got the filth off.
Check the state of the bypass screw Very Happy
This forum is having a bad effect on me. Parts
This forum is having a bad effect on me. Clean
the.postman
Gordon Smith wrote:Its based on Oxalic acid and Citric acid.
Rhubarb leaves (Oxalic acid) with a good squeeze of lemon (citric acid). This forum is having a bad effect on me. Evil-w12
Quote from their web site... "the oldest cleaning product in the USA"
I'll have to try some of that
Ta
1984 srx 600
1986 cbr1000f/h
