1 K100 dash light when ignition turned on Tue Jul 23, 2013 8:51 am
OZhoppo
I have been checking the K100 to make sure it is all good for roadworthy inspection.
When I turn on the ignition I get the usual flashing ABS warning light (which I know goes out once you move off) but I also get the triangle warning light flashing in sequence with the ABS warning light. Is this normal ?
I know the rear brake switch is faulty and am buying a new one.... would that be the cause of the warning light or do both lights extinguish when moving and the brakes are dabbed ?
