1Back to top Go down   k1100 into k100rs Empty k1100 into k100rs Wed Jul 10, 2013 7:42 am
bigdavergs
bigdavergs
Hi all. Some information please. Will a K1100 motor mate up to the k100 gearbox and is there
anything out of the ordinary that I need for this engine transplant?
I read somewhere that I would need a k1100 fuel pressure regulator.
Any info would be more than welcome, cheers, Dave.
2Back to top Go down   k1100 into k100rs Empty Re: k1100 into k100rs Wed Jul 10, 2013 8:35 am
If you are going to keep the K100 L Jetronic ECU then keep the K100 FPR all you should need to do is use the K100 injectors into the K1100 manifolds and use the K100 coils with the orange stacks and D7EA plugs not the DR7EA that the K1100 usually use. You will also need to use the K100 temperature sensor from the water outlet just near the front end of the throttle bodies.
3Back to top Go down   k1100 into k100rs Empty Re: k1100 into k100rs Wed Jul 10, 2013 10:37 am
bigdavergs
bigdavergs
Many thanks Rick for the info, cheers, Dave
