1 Lights always on, even without key! Sat Jun 15, 2013 12:29 am
abbocath
Hello for all of you!
Here i am again looking for help!
Yesterday when i stop the bike and turn the key of the lights still on.
They only turn of when i turn the right hand switch to the position 0.
Today i have dismantle the right hand switch and i think it´s ok. The contacts are good and it works fine.
Then i tried the ignition, and when i turn the ignition for first position the minimum light turns on and when the key goes to second position the minimum light turns off.
So i thin it´s ok too.
Even if i cut the power to the bike with the swith of the right hand the lights never turn off. I have always the lights on and the lights of tacho are on too.
What do you think it could be? What should i do first?
Thank you!
Good curves
Thank you!
Good curves
