1 Dash switchs Wed Jun 19, 2013 11:14 pm
ibjman
I note that BMW sells various red sign tiles for installation in the dash switches depending on their intended use.
I have a few switches & I hoped to move a tile from on to another, but I could not get the old one out of the flipper top. Even though I had the switch flipper handle separated from the switch body, I could not pry the tile out . Are they permanently glued in?
I have 1 switch that is a spring loaded "momentary" only switch. The tile say ABS. I assume this is an ABS reset switch?
I have 1 3 wire switch that is on/off and spring loaded momentary in the opposite direction. It has a Lamp bulb symbol on it. What would it's intended use be?
I have 1 switch that is 2 wire on/off only with an emergency warning tri-angle on it. I assume this could be for emergency flasher or any selected accessory?
Any ideas?
Thanks, Ibj...
Any ideas?
Thanks, Ibj...
