1Back to top Go down   High Temp Wire Empty High Temp Wire Mon Jul 29, 2013 7:18 pm
Does anyone know of a source for high temp wire in smaller quantities. I'm thinking the hall effect cable and other cables that run against the engine. I suppose they would have silicon or teflon based insulation.
2Back to top Go down   High Temp Wire Empty Re: High Temp Wire Mon Jul 29, 2013 10:12 pm
not always robin   ...but certainly a protective outer insulation
there are specific insulation type eg v75 and v90   (you guessed it 70 c and 90 c temp ratings )
i havent seen any multicore + sheilded cables rated for engine work recently ...although yes they would exist ...but quite specialised
perhaps standard cable and an outer sheath (insulation )  of something high temp ?
3Back to top Go down   High Temp Wire Empty Re: High Temp Wire Tue Jul 30, 2013 6:10 am
Where do you see these charlie?
I looked at rs components and they have 120C and 280C wires but the cost. Like $800 for a 100 meter roll.
4Back to top Go down   High Temp Wire Empty Re: High Temp Wire Tue Jul 30, 2013 6:54 am
The 02 sensor wires that run to a cat in the exhaust of cars are usually shielded wires perhaps a trip to the motor wreckers would be the go
5Back to top Go down   High Temp Wire Empty Re: High Temp Wire Wed Jul 31, 2013 10:43 am
the.postman
Is this the kind of thing you're looking for
Heat resistant cable
Or this
Heat resistant sleeving
1984 srx 600
1986 cbr1000f/h
