1 Front brake problem since fall Tue May 28, 2013 3:28 am
ali2908
About a month ago I used a front wheel paddock stand for the first time everything seemed ok and I left the bike for about 20 minutes. When I got back the bike had toppled over and was resting on some truss we were storing in the container the bike was in it had fallen about 45 deg pivoting on the front wheel.
Since then I have had a variety of problems, when I first rode it after the fall it had a bad vibration through the whole bike, I have got rid of that by slacking the fork pinch bolts on the wheel spindle, slackened the lower fork pinch bolts and pumped the forks up and down to re-centre the forks this helped reduce the vibration to normal but now I have problems with the brakes. The caliper on the right has less clearance than the other side giving problems with the pads centering in the caliper. I tried slackening off the lower pinch bolts on the wheel spindle and hitting the spindle with a rubber mallet which made a difference and I can now fit the pads in but I get horrendous pulsing/grabbing on the discs when I apply the brake, it is really bad at slow speeds.
What should I be looking at, the wheel spindle is one thought, have I twisted a fork leg, a disc what else should I check?
The front wheel has been checked and it is still true only needing 5 grams to balance it.
As usual any hints will be greatly received.
Ali
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
