1Back to top Go down   k100 smoking Empty k100 smoking Sat May 25, 2013 2:50 pm
je85
je85
I bought a 85 k100 that i'm trying to get in good running condition.
What I know about the bike.
The last owner had it sitting outside for at least two years with out running it.
The wiring was chewed up from mice.
When i got I repaired the wiring and got it running, but there is a problem it smokes.
Now I know that they smoke on start up when stored on the side stand.
I have ran it up to operating temp for 10 minutes multiple times but it still smokes.
When i rev it up to 3 to 4k it still smokes. The smoke is a dark grey blue color.
Any suggestions?
2Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 4:37 pm
nino
Hello Je, did you drive bike on the open road for half an hour?
3Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 4:44 pm
je85
je85
No i did not. The bike is not currently registered. I was waiting to get it running good before going through the hassle and expense of registering it.
4Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 4:53 pm
nino
je85 wrote:No i did not. The bike is not currently registered. I was waiting to get it running good before going through the hassle and expense of registering it.
I dont know what is weather like in your area, but sometimes here I had a lot of smoke after starting bike (moisture humidity), for 15 - 20 minutes. OK it was white smoke, not grey blue. Can you smell burned oil?
5Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 5:08 pm
If the bike has not ran for a while and you had a hard time to start it (trying repetitively without success), it could smoke for a while.
The only way to get rid of the smoke will be to go on the road and have the engine running at high rev.
If the bike was hard to start you may want to check if not any fuel leaked in the engine oil.
CF
k100 smoking Frog15k100 smoking Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
6Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 5:15 pm
je85
je85
When I first tried to start, it took a few cranks to prime the lines and then fired. The oil did not have any fuel in it. Before starting it I cleaned the tank of old fuel.
I just checked the valve clearance and it was within spec.
7Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 6:52 pm
Comberjohn
Comberjohn
Doubt if its anything serious.
Just needs a good 'redding out' up the road.
Incidentally, its not parking on the sidestand that causes smoking on the earlier models.
When you stop, let the engine tick over for about 8-10 seconds while upright. Switch off and park on the sidestand or centre stand.
Do that and it will never smoke again.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
8Back to top Go down   k100 smoking Empty I concur Sat May 25, 2013 7:13 pm
ibjman
ibjman
Are you absolutely suer that it has the right type of clean oil in the crankcase AND that when shut off and sitting for a while to settle, up on the center stand that you can verify absolutely that you can see a verifiable level of motor oil across the center line (tiny red dot) of the viewing sight glass on the right side?
A lot of restros here have been known to have such a cloudy window that the owner can't actually see the level properly. It's oh so easy to have the oil too full.
It's going to be fine. As soon as it's safe to do so, RUN the snot out of it.
9Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 8:43 pm
je85
je85
The oil level was across the red dot.
I guess I'll try and ride it to see if it clears up.
I can't right now, water pump has to go back in first and spline lube. I can't seem to find honda moly paste around locally, any good subsitutes?
10Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 8:48 pm
je85
je85
Is it possible to get this topic moved over to the trouble shooting section?
11Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 8:50 pm
Guard dog moly paste I think GA50 but not 100% sure on the numbers. In Oz we have the same thing called ROCOL GA50.
Its poisonprices but you can leave the remainder to your estate.
12Back to top Go down   k100 smoking Empty Re: k100 smoking Sat May 25, 2013 10:40 pm
Have a look here.
I got a jar of it sent over to Oz and it's what I use. It was cheaper to do it that way than the $70.00 that the Honda dealer wanted for their moly paste.
13Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 12:30 am
the.postman
je85 wrote:The oil level was across the red dot.
Amazon have it at a good price, only $9
http://www.amazon.com/Pro-Honda-Moly-Paste-oz/dp/B0083BWUYW
1984 srx 600
1986 cbr1000f/h
14Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 4:34 am
RicK G wrote:Guard dog moly paste I think GA50 but not 100% sure on the numbers. In Oz we have the same thing called ROCOL GA50.
Funny you should say that, I picked up a 500g tub of 50% moly grease while helping to clean up after a friends partner had died. It's a Molybond product with military ID numbers on it (the mil standards it was supplied for). It came out of Garden Island where he used to work. Lots of weird stuff had to be got rid of.
'93 K1100LT
k100 smoking K-dogs10
15Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 4:53 am
Ok...just to stir things up: The are people on some forums saying that the HondaMoly 60 paste has too much MoS2 in it so they mix it 50/50 with Wirth 3000 grease, so it sticks to what your greasing. It has been said that the Honda stuff can "dry out" over time.
HondaMoly 60 paste has 60% and Guard Dog Moly grease has 30% MoS2.
Just to confuse you people even more.
16Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 4:55 am
When I got mine it had sat for awhile and then sat for awhile longer while I did the sidecar and subframe stuff. When I got it on the road it smoked like a bastard. Ok, not sure how much bastards smoke, but it was a lot. Billowed comes to mind...clouds of it! After about 25km it stopped. That was about 6 years and 80,000km ago. Still running strong! It will blow smoke now for about 30 seconds after it sits for a week or two.
Sean.
17Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 6:15 am
[quote="AL-58"]
RicK G wrote: It's a Molybond product with military ID numbers on it (the mil standards it was supplied for). It came out of Garden Island where he used to work. Lots of weird stuff had to be got rid of.
wear gloves when you use it....highly carcinogenic ...the irony being that all really good gear is really bad for you....
KKlompy k100 smoking 2854237993
k100 smoking Au-log10
18Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 8:55 am
Alheng
Alheng
Were you from WA?
19Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 9:05 am
Were you from WA?
Nah, NSW, Garden Island is the naval base in Sydney Harbour.
'93 K1100LT
20Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 10:26 am
Alheng
Alheng
They have a Garden Island Naval base here in WA too!
21Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 10:41 am
I've seen 2 different lubricants, one for the clutch spline area and another for the rear splines. BMW recommendations for the clutch area is OPTIMOL T WHITE PASTE, a castrol product which is labelled as an assembly paste. It's cream colour.
The rear spines all seem to use a moly based greese. I got some in a tin from the UK called OPTIMOLY and it is gray coloured.
22Back to top Go down   k100 smoking Empty Covered Sun May 26, 2013 10:51 am
ibjman
ibjman
I believe that point has been covered before here in some of the previous posts before Robin joined???
Somewhere..... wasn't it discussed that there was a change in that recommendation or at least some members opinions suggested that the white paste had proven to not be durable enough for the maint. interval?
23Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 11:02 am
Well this bike has done almost 180K without a relube on the clutch spline and I still see evidence of the factory lube on the splines. That's 27 years and it still looks in good nick.
24Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 12:38 pm
walfish
walfish
The German recommendation is Staburegs it is quite pricey, check it out on their website, I managed to get some off one of the Flying Brick members out here on a holiday about 2 years back.
k100 smoking Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
26Back to top Go down   k100 smoking Empty Re: k100 smoking Sun May 26, 2013 11:11 pm
An old mate of mine used to ride a ratty-looking old K. Whenever he started it up at a rally after a night of drinking and stinking it'd blast a jet of smoke out across the camping ground (we called it mossie* control), chasing hangovers out of their tents, and he'd just shrug with a grin and say it was "old enough to smoke". A fast mile or two down the road towards home and it'd be right as rain.
*Mosquito for those of you who're Aussie vernacular challenged.
"Politics is the entertainment division of the military industrial complex."
- Frank Zappa
27Back to top Go down   k100 smoking Empty Re: k100 smoking Mon May 27, 2013 5:11 am
blaKey wrote:Ok...just to stir things up: The are people on some forums saying that the HondaMoly 60 paste has too much MoS2 in it so they mix it 50/50 with Wirth 3000 grease, so it sticks to what your greasing. It has been said that the Honda stuff can "dry out" over time.
That's not necessarily a bad thing, I spoke to some engineers at Castrol many years ago about this very thing. The reason for the high MolyDisulphide grease is when the grease dries out (eventually), the dried Moly coating is still a very effective metal to metal lubricant.
'93 K1100LT
28Back to top Go down   k100 smoking Empty Re: k100 smoking Mon May 27, 2013 5:27 am
Two Wheels Better wrote:An old mate of mine used to ride a ratty-looking old K. Whenever he started it up at a rally after a night of drinking and stinking it'd blast a jet of smoke out across the camping ground (we called it mossie* control), chasing hangovers out of their tents, and he'd just shrug with a grin and say it was "old enough to smoke". A fast mile or two down the road towards home and it'd be right as rain.
my favorite saying, whilst its smoking up the area ..........."shes just marking her territory " ....... grin
29Back to top Go down   k100 smoking Empty Re: k100 smoking Mon May 27, 2013 7:10 am
With my experience with moly it takes years to dry out and if you don't do the splines at least every tyre change you got a bad case of rocks in the head.
30Back to top Go down   k100 smoking Empty Re: k100 smoking Wed Jul 10, 2013 2:33 am
MikeisonTV
MikeisonTV
I bought the Staburegs off eBay.... and went to the dealership to pick u a spare key and took it along. the old dogs at the dealership said no no no....they they haven't used it for years. They told me to used Bel-Ray Assembly Lube. These guys have been working on Beemers for 40+years...and NO THEY DIDN"T ATTEMPT TO SELL ME ANY!
http://www.belray.com/bel-ray-assembly-lube
31Back to top Go down   k100 smoking Empty Better or just more convienient Wed Jul 10, 2013 2:47 am
ibjman
ibjman
I would not be surprised if a lot of good results were had with Staburegs for many years. I'm sure that you might be able to find newer formulas that are thought to be better for the splines, but I ask.......How good does it have to be to do an adequate job?
Does anyone know of an unplanned early failure that occurred during the life of a spline that was properly serviced with Staburegs?
I would be more inclined to believe that either product is suitable, even if the Bel Ray could be proven to be marginally better, Do we really need a better product when we have one that does the job already.
I'll eat some crow here if someone can show me their big list of Staburegs related failures.
I wonder if the good old boys in Gemany are recommending Bel Ray?
Regards, Ibj....
32Back to top Go down   k100 smoking Empty Re: k100 smoking Wed Jul 10, 2013 3:49 am
Does not matter at all if the moly grease dries out as moly is a "dry film lubricant". We used to use it dry on the Jaguar aircraft in the RAF.
33Back to top Go down   k100 smoking Empty Re: k100 smoking Sun Aug 04, 2019 1:15 am
Kafflut
Kafflut
Crazy Frog wrote:If the bike has not ran for a while and you had a hard time to start it (trying repetitively without success), it could smoke for a while.
CF
Je85, I agree with CF. I had difficult cold start on mine and mega smoke. What I did after getting the engine going(about 5 attempts) is kept it at about 1500rpm with the fast idle control. I guess for about 4 or 5 minutes - the garage was full of smoke. Full like wafting down the street. I switched off, let it cool. An hour later it started first turn, no smoke.
http://bmwk100k75.weebly.com/
34Back to top Go down   k100 smoking Empty Re: k100 smoking Sun Aug 04, 2019 2:21 am
I didn't bother reading the whole thread but one thing to note is that the rider manual from BMW recommends starting the bike and riding off immediately.  If you just let the bike idle in the driveway then they tend to foul the spark plugs.  (For some reason the K75s tend to do this a little more than K100s.)
That's my .02.
35Back to top Go down   k100 smoking Empty Re: k100 smoking Sun Aug 04, 2019 3:19 pm
siroisma
siroisma
As for myself, ive notice it smoke a little less after start up when I changed the engine oil grade to 20W50, the previous owner ran it with 10W40.
