1 Plus 1 tires Thu May 16, 2013 8:08 pm
Alheng
Can anyone confirm for me that a 140/80/17 rear will fit a standard K100RT?
Don't have to be matching but some tyres do work well with a match. I used to run a Bridgestone BT045 on the front and a Michilin Macadam in the recommended sizes and it was a good combo. I do recall TWB saying that he liked the sport demon on both ends and felt it worked better than having a combo.andyb wrote:I believe they must be a matching tyre set front and rear if you do the +1 oversize - eg Pirelli Sport Demons.
So your sticker says to fit an 18" tyre and you have an 18" Spitfire fitted. It is impossible for a 17" tyre(eg 140/90-17) to fit an 18" rim to begin with.AJ.Valente wrote:I'm a bit confused. The manual says 130/90-V17, but the sticker on my bike says 120/90-H18 (sic).
I'm running a Bridgestone Spitfire 130/90-H18,
So, the full question is; will a 140/90-17 (H or V rated) do the job?
k1/16v/1100RS are wide 3 spokes wheels to take a 160/60-18charlie99 wrote:could the rear be off a later series bike ....k1 or 16 valve something ? my wide one is 18 inch
Similar topics
